those with adapters?
Old Apr 2, 2003 | 09:05 PM
Kandied91z's Avatar
what are your torque settings setup on the adapter itself and then the wheel?
Old Apr 3, 2003 | 04:32 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
its the setting that you'd normally do on your lugnuts...was it 80 ft lbs? I forgot sorry man I put them on awhile back and forgot. I have a impact stick that has the right ft lbs so I normally dont think "hmmm...what do I set this torque wrench to...." I just think "wheres that blue impact stick" I keep hearing people saying adapters arent safe for racing. Thats total BS. I've been drifting on these adapters for awhile already and theres no problems. The adapters dont seem to be damaged in any way and everything is all good.
Old Apr 3, 2003 | 06:30 AM
H_Himmler's Avatar
aren't there special lug nuts you have to use with adapters, if so what are they ? I had a link saved somewhere but now I can't find it.
anybody sells them online ?
Old Apr 3, 2003 | 08:45 AM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
I got a spec sheet with my spacers from Skulte, they said 85 ft/lbs. I did the spacers that way and the lugs too. In a week or so you'll need to go back in and re torque them again after settling.
Oh and Kandied, I got the 2000 C5 wheels (all 4 18x9.5) on my car finally, with 2 1/4 spacers up front. Thought I could fit 2 until I saw how close it was to my strut. Thanks for your input. I just need to get a 1/4" spacer for the rear to make them equal!
Old Apr 3, 2003 | 09:28 AM
jawzforlife1's Avatar
I did mine the same as the whells specks in the book (cant remember what it was thought). But now I guess it will be 85 ft lbs now, if that is what skulte says.
Old Apr 3, 2003 | 10:10 AM
LT1guy's Avatar
Car: 1987 Trans Am
75-85 is a safe range...I think Redraif's were 75. Standard lug nuts hold them to the hub, at least on her spacers (from Salesco).
If you have a 2 piece spacer, be sure to use plenty of antiseize on the countersunk bolts that hold them together.
Old Apr 3, 2003 | 11:18 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The Vette Bakes spacers I run have deepshank style lugs.
I only drove with them on the car for 6 weeks and I had no problems.
Old Apr 3, 2003 | 01:34 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
This place sells them its where im getting mine from. Seems alot of people have gotten theres from them. heard anything abd at all about their product. adaptors
Old Apr 3, 2003 | 03:11 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I've had spacers and 4th gen 5 spokes for a few months now, with no problems at all. I torqed my lugs to 100 on both the spacers and the rims. Just to be on the safe side.
KZad
Old Apr 3, 2003 | 04:34 PM
Kandied91z's Avatar
if there are special ones i'm unaware of them.
i just used the ones that came with my adapters from andris skulte.
Old Apr 3, 2003 | 04:52 PM
REVLIMIT's Avatar
Engine: Built L98
What!!? CRAP!!! haha...I have the 2" spacers (currently running 98 SS rims) and I was planning on using these spacers when I get 18" Zo6 rims also. Hmmm...damn....
Old Apr 3, 2003 | 04:59 PM
Kandied91z's Avatar
just check your offset..........18" z06 will be alot different then the 17/18 combo.
now if you went 17/18 z06 you might get by.
InfernalVortex
Apr 20, 2021 11:31 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
romcjr
Sep 17, 2015 05:18 PM
