some pics of my sumped gas tank
Old Apr 2, 2003 | 09:48 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Here's my sump'd gas tank I just installed today with help from another member...some people I know wanted to see how these things set-up underneath so here you go.
Old Apr 2, 2003 | 09:49 PM
xpndbl3's Avatar
Car: 1984 Z28
Old Apr 3, 2003 | 01:40 AM
sllt1776's Avatar
Car: 89 Iroc-Z
i need to get one. how much and where did you get it? will it hook up to original lines and stuff
Old Apr 3, 2003 | 06:54 AM
BOTLFED's Avatar
Nice! That's on my -short list- of mods before summer hits.. I like seeing those pics, thanks!
Cheers,
Old Apr 5, 2003 | 12:11 AM
TwinTurboROC's Avatar
did u use a new tank or ur old one....and if u used the old one...isnt there something w the fuel gum thats usualy stuck to the tank making it an explosion hazzard...can ya outline what u did for me?
Old Apr 5, 2003 | 07:55 PM
xpndbl3's Avatar
Car: 1984 Z28
i used a factory 84 tank. I bought a gas tank sump through ebay from "B4CTom" he's a member on these boards. Anyways I took it to a radiator repair shop and gave them the tank for 2 days with $65 and they gave me back the tank. I showed them exactly where I wanted the sump and they outlined around it and then they cut 5 holes into the tank in the shape of a dice.
XX
-X-
XX
kinda like that....then they welded the sump on.....this creates a miniature "baffle" in there to allow the gas to stay in the sump around a turn. Then they baked off the old rust with a torch and painted it black for me. I am sure they filled the tank with an "inert gas" meaning that it's non-flammable so the tank won't explode. Hope this answers your questions.
Old Apr 6, 2003 | 03:05 AM
ok so this is a give it to a shop one.... thanks
Old Apr 6, 2003 | 02:30 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Yeah, don't EVER go welding on a gas tank that has been filled before. Even the pros, with all their knowledge and safety can get bit in the *** by this one. My dad knew a guy that had been welding tanks his entire life always took all the precautions from cleaning the tank to filling it with water before he started welding on it. Even after YEARS of doing this, one day he started on a tank and it blew up in his face. It nearly killed him. So, whatever you do, don't ever attempt to weld on a tank that has been filled before at home. I'd rather not hear about anyone else on Thirdgen.org dying anytime soon, even if it isn't related to working on cars or going fast.
Be careful out there,
Harry
R.I.P. Xenodrgn
Old Apr 6, 2003 | 04:06 PM
xpndbl3's Avatar
Car: 1984 Z28
yea i DEFINATELY didn't want to weld near a gas tank....so off to the professionals with this one. That tank could become shrapnel pretty easily i would think.
Old Apr 6, 2003 | 10:24 PM
Camarokid01's Avatar
Is that the same sump that they sell in Jegs and Summit? Would you happen to have anymore pictures of it?
Thanks,
Aaron
Old Apr 7, 2003 | 01:02 AM
xpndbl3's Avatar
Car: 1984 Z28
nope those are the only pics....i'll put more up when i finish the fuel lines. Anyways yea....it's really similar to the jeg's one. My friend has that one welded onto his gas tank. Works out well for him too. Now if only i could finish this car for spring.....
Old Aug 26, 2003 | 07:22 PM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
Transmission: 700R-4
Is there room for more fittings in the sump. I want to run 2 fuel pumps one for the carb and one for nitrous and would like enough fittings to hook up both. Or can you weld 2 sumps on? Anyone know where to get the bungs for the fittings, I'm going to run 3/8" line I think?
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
