mixing up 16" iroc rims
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I bought 6 Iroc 16s last fall, 3front and 3rear
I put 2 drag radials on my rear tires so I am left with 2 more rims
1 front 1 rear, I would like to buy another set of tall highway tires to put on for driving to the track and back (400km)
what is the difference between the front and rear rims? just the widths? Is it safe to run the same tire on each rim, if I end up with two different tire diameters, that will spell doom for my diff....
Car: 88 IROC Convertible
Transmission: Raptor 700
you could do it i believe, the offsets are just different between the front and rear rims, if you put the front rims on the rear they'll stick out a little a bit, and i run teh same tires on all 4 rims so that shouldn't be a problem
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
you can use the "front" wheels all the way around. they will stick out a little more when installed on the rear. not too noticeable though.
Car: 1987 IROC
Transmission: 7004r
Yea I noticed what it was right after I posted. The offset is about 1" off on the rear. I think that would look goofy, the widths are the same though. Oh well, I will have to see if someone has a rear one to sell or trade me.
Car: '87 Camaro LT
Engine: 355 L98
the difference between front and rear wheels is only the offset. fronts have 55mm less, so they stick out more. they will fit fine in the rear but rear wheels will not fit on the front.
Car: '87 Camaro LT
Engine: 355 L98
Originally posted by DJP87Z28
Only one problem: He has (ONE FRONT) & (ONE REAR) which is sort of hard to do with one each.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Why do you think the wheels are marked (front) & (rear)????
Engine: TPI 305/ v6
Wrong! Try again.....
Please... enlighten me on the true reason for pointless offsets the GM gawds bestowed upon thy sacred vehicles since you are so vasty wise about this. I seek education from your infinate knowledge and wisdom to this subject matter.
Jer... it's not going to hurt a damm thing to run a front and rear tire on the rear of the car. It will just look wierd.
mustangman65_79
Aug 11, 2015 03:17 PM
