post ur custom mod pics
Car: 1982 Trans Am
Engine: 305 crossfire
Re: post ur custom mod pics
Gonna go with the 1-2 season dash to have that original look of a 82'. And cuz i still use my original front turn signals just like the 1st season KITT had in few episodes.
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Had this really cool looking shifter **** custom made. The swirls are like those on a bowling ball, and the Z28 looks like it inside the ball. Also have an extra one with IROC-Z in red.. ( off the IROC i was restoring ).
Stone
Stone
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
would you happen to want to make another one of those?
Engine: 5.7
Transmission: 700R
Contact Chris at Speed Dawg, he's good people. He custom made mine. What exactly were you looking for..? I have one that has iroc in red, and one that has z28 ib 4th generation font.
but his number is 717-741-2665 tell him I sent you.. Stone (he knows me as Rudolf)
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
I was actauly looking on for my jeep tj since its a 5spd and my camaro is an auto. I am looking for one with the name taje on it shift **** wich is the name of my jeep
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I've got a shift **** sit the Z28 logo engraved into it.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
heres my custom gauge panel and grant wheel. best interior mod so far.
and i painted it hugger orange.
Custom SFCs
custom front subframe support and tranny pan protection
all coated and installed
Engine: Cammed 6.0L LSX
This is my newest custom modification:
'91/'92 Z28 highrise spoiler, modded to fit the stock quarter panel plastic caps on a convertible. I really wish the car was clean in the 2nd pic
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Cool "BlueZee" why didn't chevrolet think of that,.....lol
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
I have a 1990 Pontiac Firebird. 350 Chevy Small Block, Circle track milled heads, Carburetor, NASCAR Moroso Valve covers and SPECTRE air filter. My dad painted it. Costed us $300.00 total for all supplies. $250.00 Cragar Wheels, Paid $65.00 for all four Dayton Daytona SR White Letters, LED Under-glow, Driving Lights replaced the broken fog lights, $53.00 for the Pontiac Racing and FIREBIRD decals and NITE-Shaded taillights and much much more to come loll. Comment please(:
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I got them from LEDGLOW.com Came to like $65.00 and that included shipping+handling. Easy to install to(: Very pleased with them!
Engine: 4++,350 & 305 CIs
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
here are some pics of my car
Awesome build, very nice fab work for sure. Clean welds too!
Damn, is that really your 1st project? That's better than a lot of people pull of on their XXXth build
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Car: 91 Camaro RS
u know usually when someone does an engine swap, thats the only thing they swap...not the whole car. amazing work, and you plan to drive this on the street? i bet the first r!cer you meet at a stop light is gonna **** his pants.
Engine: 305 TBI
Engine: 305 TBI
here are some pics right after i did it.
Im unsure. Ive always considered doing it,but i really like mine the way they are now. Its a 50 50
Engine: 305 TBI
your car would look reallllly good with tinted lights...and remember you can always pick up another set if you want to switch out.
Engine: 305 TBI
good, heres what i did:
-used 2000 grit sand paper and wet sanded the clear coat off
-took wet towel and cleaned the lights off and a dry towel to dry them with
-tape off the backup lights (unless you can afford to fix body damage)
-take VHT nightshades and give 3 medium coats (not to dark but just right)
-wait for it to dry then do 3 to 4 coats clear and i would suggest clear coating the piece between the lights because it will look uniform
Im changing the radio to a boss flip out but you get the general idea removed airvents because its a t top ill be fine and moved radio so i can add toggle switches to replace factory radio
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Engine: 305 tbi
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Car: 91 GTA
Engine: 377ci
Car: 91 GTA
Engine: 377ci
Not sure if I have pictures for all mods but I will list some stuff.
Vents and door handles done in black
79 3" tips made out of stainless and chromed.
I put this together and stuck it under the car. Yukon aluminum center chunk, and PBR backing plates.
Little Mod after Pioneer used the car on PT for a full install.
