Looky, looky what I got!
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Aluminum drive shaft! Its from a 4th gen LS1 car!
Got some Mothers & started to polish & look what was under the plain exterior...
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
can you tell me exactly how to use mothers... i got it... having difficulties with it...
it says you rub it on, then rub it off with another cloth?
Car: 1987 GTA
Transmission: 4L60e
Beautiful piece redraif. I can't wait to see the underside of that 82 with all paint matched/polished equipment. will be a site to see for sure
One more toy! 3.73 disc brake rear. Will be painted red and installed in teh next few weeks!
Rotors are even in good shape. Get them turned and I will ready to roll!
I noticed with that mother's metal polish, the longer you let it dry, the harder it is to buff it out. I usually polish it like said above until the cloth turns black, then right after, wipe it down with a cotton towel. I also noticed that if you don't give it time to dry, you get a better shine out of it. Plus, on the directions, it doesn't even say to let it sit and dry, so there you go. -89IRO
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i picked up a disc brake rear for $50! i have no idea what kind of gear ratio it has. my dad and i needed the axle out of it for his car cause we broke an axle off the line at Atlanta Dragway. There was a lady that had a whole rearend and she didn't need it cause she had just picked up a dana44 for her car. so we bought it off her for $50! the rearend will get good gears if it has crappy ones and i will probably put some mosier custom axles and c=clip elminators in that beast before i put it in my 89. my dad got a 9inch for his car with 33spline axles so, needless to say, he won't be using th 7.5 much longer
Thanks Dan, I know what there benefits are, now I'm trying to find out what will work and what doesn't on a 350 with a 700r4 trans and a fourth gen disc rear, which is what I will be set up with. Would I need a stock aluminum driveshaft from a third gen or would a fourth gen work????.........
NEEDforSPEED
May 10, 2005 01:46 AM
