golf ball finish
Old Apr 13, 2003 | 04:04 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
golf ball finish
ok my paint has a golf ball like finish......will wetsanding fix this.....what grit should i use and do i just sand with a block while i have like a hose pouring over it or what
Old Apr 13, 2003 | 04:20 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
thats also called orange peal, i had some on my 87 formula, i wet sanded it with 400, then painted it and then redanded with 1500. all wet sanding, i did it outside in the rain, cheapest way.
Old Apr 13, 2003 | 04:56 PM
Car: 83 Camaro
Transmission: th350
so on new paint what should i do....i was thinking 1500 but i wasnt sure if i should go with 1000 first
Old Apr 13, 2003 | 05:51 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Finally, someone else says orange peal. Anytime I say orange peal effect and paint none of my friends know what I mean.
Try the 400 grit then another quick coat and something a little better like 1000ish.
I know ppl who have just gone over it will 400, then 1000, then buffed it till they got the finish they wanted. But its up to you.
Old Apr 13, 2003 | 05:56 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
it might be fisheye and thats not so easy to take care of, repaint is about the only way to get rid of that
with the golf ball description it sounds more like fisheye
Old Apr 13, 2003 | 06:05 PM
Car: 83 Camaro
Transmission: th350
its not real bad....like you cant feel it...only see it
Old Apr 13, 2003 | 07:32 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
Yes its called Orange peel!!!! Golf ball looks like fisheye,,,and fisheyes are what you get from trying to paint over Amour-all.
First off you do have base/clear paint right?
yah sence your not painting it dont go lower then 1500 or so.
But you should only let a pro do it cause you can easly sand thru the clear and worst of all go thru the base. Then youll have to get it profecioaly buffed with a high speed pro. buffer with swirl remover. And you can easly burn thru the paint with this too so its best to get someone else to do it!
Old Apr 13, 2003 | 07:43 PM
Car: 83 Camaro
Transmission: th350
how much do you think that would cost?....its not a base clear...just one stage
Old Apr 13, 2003 | 08:19 PM
BTS88IROC's Avatar
If you sand with 1500 or 2000 all you are going to do is smooth it out a little, you aren't going to get rid of the orange peel. For a better finish you could start out at like 600 and then work your way up to 2000. Thats alot of sanding though and like another said if you don't know what your doing it would be easy to cut through the clear coat and possibly the base coat.
Old Apr 13, 2003 | 08:21 PM
BTS88IROC's Avatar
I guess I didn't see your last post before I posted, any reason why you painted it in single stage instead of BC/CC? Or was it painted like that when you got it?
Old Apr 14, 2003 | 08:09 AM
Car: '81 Trans Am
Engine: 6.6L
Yha i dont think you can wetsand it then........you can still get it pro. buffed (not just waxed) but have the guys put the compounds to it with a highspeed buffer. I dont how much it would cost. Take it in for a quote at a detailing shop most detaileing or auto body shops should have the equip to do it. Ask them if they think your orange peel will come out? Im not to sure if it can because its not a base/clear paint.
Old Apr 14, 2003 | 08:44 AM
Dan88IrocZ's Avatar
I'd take 2000 grit, and run a hose over the area as you sand it very very lightly. If that fails, take it to the body shop and open your wallet
Old Apr 14, 2003 | 09:10 AM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
wetsand with 1500 grit and then buff it out and then wax it. it will take care of your problems provided it is orangepeel and not fisheyes. i believe if it's lacquer (unlikely) or single-stage urethane then you can wetsand it. i think it's just acrylic enamel you cannot wetsand. If the paint is new, go to the store the paint came from or the people who painted it to find out exactly what kind of paint was used and if it can be wetsanded.
Old Apr 14, 2003 | 11:10 AM
Irhal's Avatar
Car: 94 Firebird
Engine: 3.4L
Transmission: t5
you can sand enamel after a year or 2... that paint is very slow to harden... if you sand it when it is not yet hardened... it will look nice for a day or two, then become matt (sp?) again... 400 grit is very harsh I wouldn't suggest it... go with 800 water grit... orange peel is a slow process to get rid of... patience and good hands are the only way... after the 800 you go with 1500 then 2000 then you buff the paint... that's how we do it in my bodyshop
Ed1LE
Sep 30, 2018 09:14 AM
88CamZ
Oct 8, 2015 10:29 AM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
