Is a dremel my answer?
Old May 7, 2003 | 06:48 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey I'm sanding my air conditioning bracket a little bit everyday. Some day at sears I remember seeing a dremel catalog showing one taking away rust on an old chair. Would it be a good idea to use one to take the paint off this?
Old May 7, 2003 | 08:48 PM
91RedBigFinZ's Avatar
Any excuse to get a dremel is a good one. I use mine for everything. I would get a corded one though, the battery can run out fast when you are doing a lot of sanding/grinding.
Doug
Old May 7, 2003 | 08:59 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
make shure its a good one
ive had a couple and all of them have burned up on me make shure you get a good quality one they prolly burned up cause teh ones i had could get up to 30000 rpm and i used it alot at that speed
Old May 7, 2003 | 09:09 PM
383 rocket bird's Avatar
I have one called the Wizard and it comes with a real small extandable flexible corder end. It is adjustable from 3,000-6,000 rpm and i also use it for everything.
Old May 8, 2003 | 03:25 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
air tools own!:hail:
Old May 8, 2003 | 11:13 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
The Dremmel is the answer to MANY things. I need an excuse to get one myself.
Old May 8, 2003 | 11:26 AM
5SIZ's Avatar
Car: 1987 IROC-Z
i always end up having to borrow my friends dremel for projects, mainly porting and gasket matching my slp runners.
i would get one if i had the spare cash to do so.
Old May 10, 2003 | 08:16 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I have a dremel as well, beware as some units overheat pretty easily. The first one I bought had the vents positioned very poorly and my hand would always block the vents with the way they made you hold it. I returned that POS and got a good one.
Old May 10, 2003 | 10:00 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Just got one today from home depot. Its a mulitpro 3961-02 made by Dremel. Variable speed up to 35000 rpm. I noticed that it stays the same temp whether its going at 5000 or 35000 rpm.
It cost $60.
Fronzizzle
Feb 9, 2017 09:31 AM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
