making 91/92 Z28 hood blisters functional
Old Jun 9, 2003 | 10:34 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
before i go and hack apart a pair of perfectly good 91/92 Z28 hood blisters (and my hood for that matter)
i would like to know if anybody has done this
its obvious what i am going to try to do:
cut out the fake black rubber "grille" part and also cut out the corresponding area underneath them on the hood
i think this is a great idea, not too worried about rain entering, because i think i have a way around that
also, is there anyplace i can get a sort of black rubber molding that i can put around the cut areas and the areas on the hood
and for that matter, like a weatherstripping to seal the openings to the hood......................
Old Jun 9, 2003 | 11:21 PM
BTS88IROC's Avatar
You would only be able to cut out the small section where the vent would be under the hood. If you cut out the whole louver section under the hood there wouldn't be any place for the louver too mount. Seems like too much work for too little gain.
Old Jun 9, 2003 | 11:27 PM
i know, thats exactly what i was trying to state
yes, its a little gain, but its a free mod, especially considering my car is carbed
Old Jun 9, 2003 | 11:37 PM
FLYNLOW92rs's Avatar
It's been done before and posted.....
I just can't find it on a search.....
Old Jun 9, 2003 | 11:44 PM
BTS88IROC's Avatar
I too remember that thread. But it was some time ago. Maybe its already in the archives. I ran a search and didn't see anything either.
Old Jun 10, 2003 | 12:05 AM
http://www.lbsz28blown.cz28.com/photo.html
i'm doing it
Old Jun 10, 2003 | 06:41 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
If you need any more Info or pics let me Know and I'll post them
here.
Old Jun 10, 2003 | 07:04 AM
Here's some pics.
Old Jun 10, 2003 | 07:21 AM
For some reason this pic link is not working,
so just copy and paste the address.
Old Jun 10, 2003 | 08:07 AM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
If you could please post more info on this, i have been thinking of doing this for a while but don't want to take the chance of destroying my blisters.
Old Jun 10, 2003 | 11:04 AM
Remove the Hood Insulation for accesses to the Hood Blister attachment hardware.
Remove the Hood blisters, be careful not to scratch the hood, I would suggest Two people.
I placed My Hood Blisters upside down on some soft Towels
Next I used a cutting wheel on my die grinder and did a rough cut (undersized) To remove the openings.
Then I used some grinding bits and slowly ground out the remainder of the openings.
You’ll note that the edges of the opening will not match your paint and will require some touchup paint.
Next I found some screen or grill/grate at the local Hardware store and cut it to size and epoxy it to the underside of the Blister openings.
Now the tricky part
The holes in the hood.
I choose my locations for my holes because If I wash my car all the water misses my engine and falls just AFTof the radiator and FWD of the engine, this equates to Much less time to detail all the shiny stuff on my Engine.
You can choose a different area for the holes if you so desire.
So what I did was Tape (Masking tape) the painted side (top of hood) of hood where the blisters sit and located where my square holes are to be cut, the hole started at the front just aft of the attachment point and stopped just before the next center support point ( holes are about 4” x 4” square) check pic at (http://lbsz28blown.cz28.com/images/dscn0004(1).jpg) you may have to copy and paste to get to pic.
I used a jigsaw and then a grinding wheel then a file to cleanup the holes.
Put the Car back together and enjoy.
Good Luck
Old Jun 10, 2003 | 11:10 AM
If anybody interested my Hood and ram air setup to the blower are for sale. Good price.
send me a Private message or e-mail.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
