Picked up an RAII hood today. Pics inside
Old Jun 14, 2003 | 01:15 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Traded some car parts for this hood. Looks pretty good, just need to adjust the latch so the hood closes lower.
I also put the lowering springs on the front,
Old Jun 14, 2003 | 01:21 AM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
looks good man
Old Jun 14, 2003 | 01:22 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
SAWEET!!
Looks tough
Old Jun 14, 2003 | 01:30 AM
Zepher's Avatar
Thanks guys.
I am debating if I want to paint it though since it will eventually find it's way onto my Black 86 Trans Am. I just installed it on the Formula so that it doesn't get damaged in my garage which is quite packed with the Trans Am and a bunch of parts.
Oh, and my Trans Am doesn't have any springs on the front, was too pissed off to put them in since it was 4am and we'd been working on the front springs swap for 8 hours.
all the bolts on the Formula were rusted, took about 4 hours per side to get the springs out.
Old Jun 14, 2003 | 02:13 AM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
nice man nice but ill tell you it took me weeks to get my Ram air II hood on right ...Only to end up hateing it selling it and putting my RA1 back on i hope your tall cause man im 6 4 and I STILL had trouble seeing over the turd
Old Jun 14, 2003 | 02:17 AM
Zepher's Avatar
I am 5'7 and since I have the lowering spring on the front right now, clearance is fine since the rear is higher.
I wanted the RA1 hood, but this was a decent deal so I couldn't pass it up.
I may leave this on the Formula and get the RA1 hood for the T/A, but right now, I plan on putting the RAII on the T/A.
Old Jun 14, 2003 | 02:18 AM
wanna trade?
Old Jun 14, 2003 | 02:26 AM
Zepher's Avatar
Originally posted by Badazz86z28
wanna trade?
Sure, I'll trade.
get on aim RAMAIR88FIREBIRD is my sn
Old Jun 14, 2003 | 12:14 PM
MdFormula350's Avatar
it looks really good on the formula, i wanted the ram air 1 to happen on my car but it didnt seem to fit to well and of coarse the hood spring issue.
Old Jun 14, 2003 | 12:35 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
noooooo!
Old Jun 14, 2003 | 01:48 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
That is the sweetest hood ever. You have the same nose on your Formula as I do on my Trans Am and I always wondered what a hood would look like. Sweet cars.
Steve
Old Jun 14, 2003 | 05:02 PM
Zepher's Avatar
Thanks.
I think it looks pretty decent. Very agressive looking.
I am probably going to swap it for a RA1 hood soon though.
Old Jun 14, 2003 | 05:14 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Dude, please get your other car started before doing more to this "new" car! You're like me, keep buying new parts and putting off the main task at hand. lol By the way, it does look pretty sweet, should look better when it if fitted properly!
Old Jun 14, 2003 | 05:19 PM
Zepher's Avatar
It's just soo hard to concentrate on the Trans Am since it requires so much more work.
I am going to be working on it all this week. Need to get the dash installed and do the wiring.
I am going to hold off on the Formula for a bit, I've done quite a bit to it in the past couple of weeks.
Old Jun 14, 2003 | 05:24 PM
samdog1232000's Avatar
Car: 92 RS 25th Anniversary
Engine: 350 L98 w/Vortec Heads
Transmission: 700 R4
When I bought my SS hood I had trouble fitting it in properly! Even the guy that painted and did the body work could not get it perfect. One side of the hood is flush with the fender and the other side isnt. He said the only way to fix it is to move the fender and what not so he did not mess with it It is not to bad though, people wont notice it until I point it out.
Old Jun 14, 2003 | 05:32 PM
Zepher's Avatar
mine rubs the pass side fender. I'll align it today when my brother gets back and see how much better it sits.
Old Jun 14, 2003 | 05:34 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
looks good, now the car needs rims bad.
I know of a set of 17" Firehawks being raffled off
Old Jun 14, 2003 | 05:44 PM
Zepher's Avatar
those 17's would look awesome on my car.
The OZ's are going to go on the Formula unless someone trades me for some ZR1 style wheels.
Old Jun 15, 2003 | 12:15 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
Keep the power bulge hood for the T/A =)
Old Jun 15, 2003 | 12:39 AM
devianb's Avatar
Zepher,
When did you get a Formula?
Hood looks good. I have trouble enough seeing over the stock flat hood, so a RA 1 or 2 is definately out of the question.
Old Jun 15, 2003 | 01:57 AM
Zepher's Avatar
Originally posted by devianb
Zepher,
I got the Formula 2 weeks ago. Visibilty is fine, even though I am short, 5'7". Since the rear is raised and the front is lowered, giving it that raked look, I can see over the hood fine.
Old Jun 15, 2003 | 07:57 PM
devianb's Avatar
Lol, you must sit higher in your seat bacause I am 5' 7" too. I usually sit kind of slouched so the top half of my steering wheel divides the windshield in half.
Old Jun 16, 2003 | 01:07 AM
Zepher's Avatar
Are you lying down in your car?
I have my tilt wheel all the way down and I have my seat at a 45* angle.
Old Jun 16, 2003 | 05:32 PM
trigger GTA's Avatar
Car: 92 TA vert
Zepher did you get the hood to fit right? or did you not try to get a good fit. and just took it back off after the pic?
Old Jun 16, 2003 | 05:56 PM
Zepher's Avatar
I fitted the front a little better, haven't adjusted the sides yet.
It still needs to sit lower in the front.
I am swapping it this weekend, so I am not really going to bother with it.
yep yep
Old Jun 16, 2003 | 06:06 PM
Car: 92 TA vert
i got mine on the car today and i got to tell you so far i am not impressed. i had to take all the bump stops compleatly out to get it to sit low enough. but its still WAY out at the head lights. if you take a look at the pic you will see that the head light is right on with the fenders and the hood is way off.
not sure how to fix it at this point
http://members.rogers.com/swhitten/DSC00729.JPG
Old Jun 16, 2003 | 06:08 PM
ok the secert is you have to work on it
sanding putting shams in all moving it around on the bolt took me 7 hours to do it on my friends car
Old Jun 16, 2003 | 06:15 PM
Car: 92 TA vert
a hole day just to fit it.
its out over 1/2 an inch in the space of the headlight. that cant be right. for the most part it fits fine. but right at the light
ok so can i shim the headlight?
what about the fenders? can they be raised and not though out the door lines? and the nose?
i dont think i will be so lucky to have the hood start to sage after being on the car for a day or two
the way it looks the one corner HAS to come down
Old Jun 16, 2003 | 06:52 PM
no no no
what you do is loosen the bolts and just pull toward the front of the car till it lines up
Old Jun 16, 2003 | 07:04 PM
Car: 92 TA vert
ok heres a different pic. that helps so see. the hood for the most part lined up right away you can see that the very front is down to far. but the one side is way off and moving the hood i dont think will help it line up better.
i could be worng
http://members.rogers.com/swhitten/DSC00734.JPG
ps sorry Zepher for the high jack
Old Jun 16, 2003 | 07:05 PM
it only does that because theres alot of torque on it look for it catching on somthing
Old Jun 16, 2003 | 07:06 PM
its ok for the highjack cause hes trading the hood to me so its all good umm send me a pic of the other side
Old Jun 16, 2003 | 07:09 PM
Zepher's Avatar
Is it possible to heat up the hood a bit and put a weight on that corner to get it to come down a bit?
Old Jun 16, 2003 | 07:10 PM
Car: 92 TA vert
its not as bad.
in all the pics you see i have the bump stops out and the hood is resting on the metal just in front of the rad. there is nothing stopping it or putting stess on it
http://members.rogers.com/swhitten/DSC00731.JPG
Old Jun 16, 2003 | 07:12 PM
ok then you need to put your hood stops on to Stress it in the top so it has to bend forward and zep i doupt it youd have to get it EXTREAMLY hot because fiberglass is like bondo with plastic
Old Jun 16, 2003 | 07:13 PM
Car: 92 TA vert
sorry i need to clear it up a bit. the bump stops i took out are in the front. on at the head light motor and the other just in front of the rad on both sides
Old Jun 16, 2003 | 07:14 PM
oh well **** man i dont have a clue... loosen the screws and play with it some more all i can say
Old Jul 8, 2003 | 08:57 PM
gtabadboy's Avatar
Any progress on fitting the hoods? I am having a whole lot of trouble getting my RAII right. The sides are good as far as space from the fenders but the hood sits too high over the fender like the previous pics. This is ridiculous. A hood made for a TA should fit!!!
Old Jul 8, 2003 | 09:16 PM
Zepher's Avatar
I got it to fit a bit better.
here is a video of the car moving so you can see it,
http://www.transamws6.com/video/Formula.wmv
Old Jul 9, 2003 | 11:06 AM
  #42
gtabadboy's Avatar
Wow that looks good. How did you get it to come down more in the front sides. I am considering hood pins but Im not sure how I feel about them on our cars.
Old Jul 9, 2003 | 11:07 AM
  #43
Zepher's Avatar
I just moved the latch all the way down.
It can use a little more fine tuning, but it is ok how it is now.
Old Jul 9, 2003 | 05:03 PM
  #44
Car: 92 TA vert
mine get shipped back tomorrow.
i think i may have gotten a bad one
rexorr is taking care of me. so far they have been great to deal with.
Old Jul 9, 2003 | 05:33 PM
  #45
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Do you do laps around your yard for the hell of it? Or are you an aspiring Nascar driver?
Old Jul 9, 2003 | 08:21 PM
  #46
Zepher's Avatar
We park one car in the backyard so it doesn't have to sit on the street. My brothers car was hit by the people across the street but they didn't come and tell us but we knew it was them or one of thier friends by the angle the car was hit.
Old Jul 9, 2003 | 09:16 PM
  #47
Ruddigger's Avatar
Word...
Old Jul 9, 2003 | 11:01 PM
  #48
Zepher's Avatar
I am parting out the T/A right now. so if anyone needs anything, let me know.
Old Jul 10, 2003 | 11:02 AM
  #49
88blackbird's Avatar
Car: 88 Trans Am GTA
Your parting out your black T/A???
Old Jul 10, 2003 | 12:44 PM
  #50
Zepher's Avatar
Yes I am, or selling it as a whole, minus the drivetrain. $1500.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
sailtexas186548
Feb 29, 2016 08:40 AM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
