Pics Of ME and MINIME
Old Jun 16, 2003 | 11:02 AM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Here are some pictures of "Me" and "Minime". Took some time to get minime done but overall it came out pretty well. I guess I could have went even more crazy but I had to draw the line somewhere. Fabing the rollbar was enough in itself. So, what do you think?
Old Jun 16, 2003 | 11:04 AM
ryn28's Avatar
Engine: Chevy ZZ4
Pic 2:
-N-'s Avatar
-N-
Car: 1984 Berlinetta
Nice job. What did you use to make it?
Old Jun 16, 2003 | 11:10 AM
87transam5.7tpi's Avatar
thats pretty crazy man, looks good though
Old Jun 16, 2003 | 03:26 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
thats pretty cool, Ive been trying to find a model so i can build one
Old Jun 16, 2003 | 03:47 PM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
Too much time on your hands? looks cool.
Old Jun 16, 2003 | 03:59 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
You got way too much time over, get a job. The mini car looks great. Wish i had one.
Old Jun 16, 2003 | 05:15 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
lol, that's cool as he!!
Old Jun 16, 2003 | 05:51 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
What would you say about this one then.
http://www.cecoatings.com/images/one8thscale/
ryan, what modle is that? I have a 1/8th Scale Z and a regular 1/24th 92Z
Old Jun 16, 2003 | 06:17 PM
devianb's Avatar
Lol, comical.
Old Jun 16, 2003 | 07:35 PM
Nate's 88's Avatar
what brand of models are these guys, I'll have to go order one if I can find it.
Old Jun 16, 2003 | 11:20 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
The only plastic model kits ThirdGen in production currently are the (1:24) 1983 Z-28, by AMT. This should be available at most hobby shops, and somethimes at Wal-Mart. (about $10) There are some die-cast metal ones that show up in toy stores from time to time, but I don't count them. There is also the 1:8 scale 83 Camaro from Monogram, but those cost some $$ and are often hard to find.
There is also a KITT in limited release, and a 1991 Firebird Pro-Stock/Street.
For other year Camaros, and all of the Firebird/Trans Am/GTA's, you will need to hit the swap meets, E-bay, or check out www.modelroundup.com, for the out of production kits. Be prepared to pay $20-30 for them.
If you have a good, old-time, hobby store near by, they may often buy up old kits and resell them. I got lucky and found a somewhat smashed GTA for $4. I'm converting it back to '86 T/A trim.
Which brings me to my last note:
All of the AMT plastic kits use the same chassis, so you could fit a Camaro body on the Pro-Stock Firebird chassis. The Firebirds also use a common body with add-on GFX and front/rear bumpers, just like the real ones, so you could put 91 GFX on a Notchback GTA, if you wanted.
Raise your hand if you think I'm a model car geek:
Old Jun 17, 2003 | 03:35 PM
ryn28's Avatar
Engine: Chevy ZZ4
Thanks for the compliments guys.
TP|383 that looks amazing. My model is 1/25 scale so that kind of detail would probably take me a lifetime.
The model I used was an AMT 1/25 1989 Iroc. I bought it off of ebay. Do a search for "iroc camaro" and then click on models. They usually go between $25-$40. I found one that was open but complete which is the one you see here. I have two more that are factory sealed which I'm keeping since they are discontinued. AMT has a few other Camaro models but not all come with the TPI engine. Now "minime" sits in a plastic display case for safe keeping.
For the tires I got them from:
http://www.americansatco.com/
And the wheels from:
http://www.afxnscaleresin.150m.com/drag_wheels.htm
The skinny fronts were too small diameter so I cut the stock tires in half and used those. The rears were too wide so I cut and sanded those too. They are only held in by wedging them in the wheel well since they are so big. Works good enough for me.
Wow, I guess I did have too much time on my hands
Old Jun 17, 2003 | 03:44 PM
ryn28's Avatar
Engine: Chevy ZZ4
Here's a pic of the model kit I used and of minime in it's "garage" above my Sunstar 1982 Camaro 1/8 scale model.
Old Jun 18, 2003 | 01:27 PM
Nate's 88's Avatar
found the 1983 z28 today and also found this, supposed to be limited edition.
Old Jun 18, 2003 | 01:30 PM
Nate's 88's Avatar
there is also a factory '70 1/2 camaro out but i dont know if it's limited edition or not, also I found the 1/8 scale camaro, if i hadnt looked up i would have missed it tho. wanted 60 bucks for it i believe, after taxes and all it would have been 60 anyways. just couldnt justify paying $60 for a model while my car sits on jackstands in the garage.
Old Jun 19, 2003 | 07:26 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Yep my 1/8th Scale cost me $75 after tax
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
