Some underhood appearance mods
Old Jun 26, 2003 | 02:04 PM
llvll4l2c91350's Avatar
Before:
Old Jun 26, 2003 | 02:05 PM
After:
a friend and i worked on the wires. it actually was pretty time consuming, but well worth it i think.
Old Jun 26, 2003 | 02:14 PM
MdFormula350's Avatar
great job, looks great.
Old Jun 26, 2003 | 02:48 PM
Berlinetta82's Avatar
I like those wire looms or whatever they are called.
Old Jun 26, 2003 | 02:57 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
looks nice and neat!
Old Jun 26, 2003 | 03:00 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I was wanting to do that with mine, wasn't sure how they would turn out with centerbolt valve covers. Also I still have the stock manifold and for some reason I was thinking I would have to run a wire or two directly over or through the manifold. I do not remember having as much clearance as you seem to with headers in those pics.
Old Jun 26, 2003 | 05:41 PM
thanks. i love the look with the red wires and black covers. but im concerned about some wires being close to the primary tubes and some touching the air tubes. would it be a good idea to wrap 'em with somethin? dont wanna burn up brand new MSD's.
Old Jun 26, 2003 | 05:59 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
looks good. how come u changed to black valve covers?
Old Jun 26, 2003 | 06:02 PM
they're just painted black. i thought it would look good with the red wires and looms. i was right.
Old Jun 26, 2003 | 08:34 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Excellent! now I know what mine will look like whenever I get around to putting them on...I have had them for 2 years sitting on my shelf....
Did you use the 8mm wire looms on 8.5mm wires? I remember you had posted a thread about them fitting...
They seem to fit pretty good..
Old Jun 26, 2003 | 08:37 PM
WillWood's Avatar
Car: 1966 Volkswagen Beetle
Engine: Flat-4
Transmission: swing axle
Looks great, did you do the a/c delete yourself?
Old Jun 26, 2003 | 08:40 PM
yeah i did the a/c delete my self. got the box from ebay and the pulley from gmpartsdirect.
and i did use the 8.5mm wires with the 8mm looms. they fit fine, just a lil tight.
only problem was the looms on the driver's side are turned around 180* from where they're supposed to be, cuz the airtube on the header was in the way.
Old Jun 26, 2003 | 08:49 PM
Makaveli's Avatar
looks great, i like the black valve cover look too.
Old Jun 27, 2003 | 12:16 AM
25THRSS's Avatar
looks good
Old Jun 27, 2003 | 12:32 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I thought it was to match the headers.
I would say polishing would brighten it up even more.
Old Jun 27, 2003 | 01:03 AM
definitely still gotta do that. just need more time.
Old Jun 27, 2003 | 03:07 AM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Damn... your engine bay is clean! I am massively jealous. And the wires, nice touch. Made a clean bay even cleaner.
Old Jun 27, 2003 | 10:00 AM
19WS6T/A91's Avatar
i was just about to comment on the drivers side. i just installed mine about a week ago. i used the taylor "universal" wire kit so that i could have all 90 degree bends and so that i could cut the wires to the exact length that i needed them. i was also concerned that it was going to cover up my logo on my valve cover, but it didnt, so im much happier than i planned on being with them.
Old Jun 29, 2003 | 01:07 AM
OMINOUS_87's Avatar
Looks good, but with some custom hoe work for the heater valve it could look better!
Old Jun 29, 2003 | 09:20 PM
i sure wouldn't mind seeing a hoe do some custom work on my valve.
Old Jun 29, 2003 | 09:25 PM
Old Jun 29, 2003 | 09:29 PM
I'll be in the same boat here soon...
Old Jun 30, 2003 | 12:16 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Hehe, nice PVC intake - how hard was it to make?
Old Jun 30, 2003 | 12:24 AM
25THRSS's Avatar
Just a thought, but couldn't you bend the air tubes away from the head so that you could put them on the right way?
Old Jun 30, 2003 | 12:29 AM
took my stock intake tube to home depot and matched it up with 2 90* elbows and straight pipe, 3" diameter. thought i was gonna have to buy a whole section of PVC pipe but they were able to cut just what i needed. grand total came to about 10 bucks. then just connect the 3 pieces, air filter and you're done.
Old Jun 30, 2003 | 12:50 AM
i thought about it, but didnt wanna do it unless i heated 'em up first. i know with some heat they'd bend easily. should've done it while i had it at the exhaust shop when they put on my y pipes.
another reason why i should've gone with Hookers!!
Old Jun 30, 2003 | 12:55 AM
OMINOUS_87's Avatar
Hose my friend!
Old Jul 1, 2003 | 08:20 PM
JimmyG-91Z's Avatar
That looks great, I love the black with red, hope you don't mind if I borrow that idea from ya
Old Jul 1, 2003 | 10:25 PM
go for it
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Linson
Oct 1, 2015 09:50 PM
gord327
Sep 29, 2015 10:18 PM
