where do the hood pins go???
Old Aug 5, 2003 | 05:53 PM
camaro 670087's Avatar
im ready to start drilling holes for my pin on hood.
its fiberglass cowl induction and pins on in the front. can anyone tell me where the pins are supposed to go? pics would be great.
thanks
Old Aug 5, 2003 | 06:15 PM
Tonyrodz's Avatar
Transmission: auto
They should go on the radiator support. The long metal bar that goes from fender to fender behind the headlights.
Old Aug 5, 2003 | 06:40 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Isn't there a way to get around hood pins on a fiberglass hood??
Old Aug 5, 2003 | 07:09 PM
yes but where on the radiator support? will i need to drill holes or do i reuse a hole that is already there?
anyone have any tipws about doing this?
Old Aug 6, 2003 | 09:19 AM
Tonyrodz's Avatar
Transmission: auto
You need to line everything up where you want it to be and drill new holes--in the rad. support and in the hood.
Old Aug 6, 2003 | 07:54 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
try this
TransAmTBI's Avatar
Engine: 305 TBI
and then
Attached Thumbnails where do the hood pins go???-right-hood-pin-hood
Old Aug 6, 2003 | 08:31 PM
oh man thanks a lot for those pics. now i know exactly where to start drilling.
im goin out to do it tomorow.
any tips on doing this? anything i should know not to do? its a fiberglass hood.
Old Aug 6, 2003 | 08:50 PM
TransAmTBI's Avatar
Engine: 305 TBI
one tip.. be carefull..
seriously idk should be no prob i would use a smaller drill bit that the hole then get a dremmal and round out the hole to how big you want! other than that good luck let mme see a b4 and after!
Old Aug 6, 2003 | 08:54 PM
TransAmTBI's Avatar
Engine: 305 TBI
by the way heres how the whole thing looks
Old Aug 7, 2003 | 11:02 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I quess mine are in about the same spot!
Old Aug 8, 2003 | 11:41 AM
alright the holes are drilled and now its time to take after pics but until then heres what it looked like way before....meaning the hood and bumper have been painted since this pic....
Old Aug 8, 2003 | 12:31 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
What kind of hood is that??
Looks an awful lot like the one that I bought for my car.
Old Aug 8, 2003 | 03:07 PM
ita an Unlimited Products 5" cowl hood
Old Aug 8, 2003 | 09:05 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
WOW 5inch.. What you have stuffed under that bad boy?
I thought my 3inch is perfect.
Old Aug 8, 2003 | 09:22 PM
its still just a 350 TPI and i am using the hood for the looks, although i am planning on building a new high performance engine so if i go carbed then the hood will be perfect for a high rise intake
Old Aug 9, 2003 | 02:19 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I mounted mine on the core support where the little bumper stop things are at.
Old Aug 10, 2003 | 01:31 AM
matts90firebird's Avatar
just make sure if u install the pin first then do the top
dont drill into the raised portion of the radiator support make sure its a lower part
if u try to put it into the higher part u will have problems like i did but do what u want
ill post pics as soon as i get my car back
2 or 3 days
i have hook locks by the bumper and hood pins up by the windshield
Check out my site and leave me a message of what u think
thanks matt
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
