Pressure washing engine bay with engine out
Old Aug 13, 2003 | 02:07 AM
BrianI's Avatar
What should I tape up or cover up?
What kind of degreaser could I use that wouldn't harm the paint?
Old Aug 13, 2003 | 02:50 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
I just pulled all of the wires upward and had them laying on the cowl piece. For cleaning, I used a pretty rich mix of SimpleGreen; it worked well against dirt and grease, it doesn't make you sick either. Worked for me anyway!
Old Aug 13, 2003 | 07:48 AM
1986redbird's Avatar
I used a mix of "tide with bleach" laundry detergent and warm water. mix a scoop of tide in a bucket of warm water, let it disolve all the way, scrub down the bay, let it sit a while to work, then pressure wash, then your ready for paint or whatever.
the results speak for themselves: :
Attached Thumbnails Pressure washing engine bay with engine out-engine-bay.jpg
Old Aug 13, 2003 | 10:49 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
that's the results of the paintjob though, i'd like to see the results of the tide and pressure wash. i sprayed the hell out of everything with simple green at like 10pm, then again at like 10am, used up a whole bottle between the 2 times. then we power washed it at like 11 or 12. it came out alright, a hell of a lot better than before, but not show quality. it would be nice if i had a hot water pressure washer, that would work so much better. we might end up painting the engine bay. i'm thinking of going with flat black or something, cuz i'm not sure what color the final paintjob is going to be.
Old Aug 13, 2003 | 01:19 PM
BADBIRD009's Avatar
i used about 5 cans of degreaser, hot water and about 4 hours worth of elbow grease with a tire brush. check out the results, not half bad considering it had probably never ever been cleaned.
Old Aug 13, 2003 | 01:29 PM
Scott C-2
Guest
Posts: n/a
Elbow grease is the key...don't be afraid to get in there and scrub!
Old Aug 14, 2003 | 01:45 AM
BrianI's Avatar
thanks guys
Old Aug 14, 2003 | 12:27 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
just be sure to avoid the critical parts that are still there. after all, wiring harnesess and brake resevouirs werent designed to handle 4500psi of water.
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
