Quick Coolant Overflow Tank Question! (Real quick!)
Old Oct 13, 2003 | 09:32 PM
Adam Jones's Avatar
I just got a new one from the dealer, and it looks slightly different from my stock 85 one. Did they change the appearance or give me the wrong one?
T.I.A.
-AJ
Old Oct 13, 2003 | 09:41 PM
joshp14's Avatar
What's different about it? Do the p/n's match?
Old Oct 13, 2003 | 10:11 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I can only recall offhand seeing two different kinds. The 82-87 (88?) were a little smaller and slightly more roundish (v-belt equipped cars) and the 88(89?)-up had a slightly larger, more square style (serpentine equipped). My old 84 camaro lg4 had the same overflow as my 87 tpi 'bird. The only thing that was visable different was the tank caps.
Not sure if there were any other tanks aside from those two types.
Old Oct 13, 2003 | 11:10 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Dunno if this will help but if you look at the left side of this picture
you can see my absolutely LOVELY coolant tank (I'll replace it someday, since it doesn't blend in with the nice clean new engine as well as it did with that nasty 305 in the pic ) Anyway, that's the stock '84 coolant tank....I don't know what the others look like, but that's what mine looks like
-Paul
Old Oct 13, 2003 | 11:17 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
sorry to hi-jack your thread, but would somethin like this work? or not because it wouldnt be able to suck coolant back in the system? i hate the way the over flow tank looks.
Old Oct 14, 2003 | 02:43 AM
Adam Jones's Avatar
P/N for the tank matches the invoice:
10170175
It is like deadbird described: slightly larger and more square style.
Is it the right p/n?
-AJ
EDIT: Just did a little searching of my own. Looks like its the 88-92 style. Is it compatible with my system?
Old Oct 14, 2003 | 07:56 AM
joshp14's Avatar
If the p/n's are the same as the bird, which they may be, here are the p/n's at my site:
http://www.geocities.com/vipervenemgts/odds_ends.html
Old Oct 18, 2003 | 04:13 AM
Red90IROC's Avatar
Car: 1991 Trans Am
Engine: 5L TPI
Thanks Joshp for hosting that info on your site. :lala:
1992 Trans Am
May 10, 2023 07:19 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
