the formula is all done for the year
Old Dec 7, 2003 | 01:21 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
First snow of the year and we get a foot and a half
i managed to get the cover and tarp over it before the snow, but had to cut a hole because the antenna is bent and would not go down.
what else should i be doing to it, i taped over the exahust pipes and air cleaner so that nothing could get into them, any other suggestions, i will at some point get under the hood and disconnect the battery and i put some sheets of mdf board under all of the tires to keep it from sitting on the ground.
Old Dec 7, 2003 | 01:34 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
it would blend in nicely with all that snow wish we could get some of that down here
Old Dec 7, 2003 | 01:35 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Move to Louisiana!!!!!!!:hail: :hail:
Old Dec 7, 2003 | 01:53 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
i would drain the gas out of the tank just to be safe. my gas went sour in my car after only 3 months. i'd probably do an oil change too...no reason really but i would get paranoid that dirty oil is settling in bad places or something. unless you plan on running the car once in a while
Old Dec 7, 2003 | 05:08 PM
onebinky's Avatar
You could just use some fuel stabilizer in the tank instead of draining it. You should definately change the oil though unless its fresh. Also might want to put an open box of baking soda in the interior incase you get any moisture leaking in. It'll soak up humidity and get rid of the mildew smell. If it's going to be sitting for more than the winter, I'd put it up on stands also to take all the stress off the suspension. It will make the springs/shocks/struts/bushings last alot longer.
Old Dec 7, 2003 | 08:57 PM
Car: 91 formula
Transmission: t5
i guess i will through some stable in it when i get a chance, it will only be there untill hopefully mid april or so :/, whenever all the snow is gone....
then it is back to
Old Dec 7, 2003 | 10:15 PM
formul8!!'s Avatar
Car: 2004 GTO
The only thing I can really recommend is a garage. Sitting outside, even with a cover all winter is not very good.
Still better than sloshing it through the metal eating salt, though.
Old Dec 8, 2003 | 11:19 AM
Car: 91 formula
Transmission: t5
i cant find a garage to put it in, or it would be in one..... i had one last year when i had my cutlass covertible, but the lady moved so i dont have a place to put it.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
lt1z350
Aug 28, 2015 05:57 AM
neekolzun
Aug 24, 2015 04:59 PM
qz6lwp
Aug 20, 2015 08:10 PM
