Powder coating
Old Dec 10, 2003 | 11:05 PM
Kaas's Avatar
Car: 89 Iroc-Z
Powder coating
ok, i posted about this awhile back and i got my Tuned Port today. I gonna take it in to the boss today to see if he'll let me powder coat it..so now i lookin for a yes or a no on weither or not it'll come out ok...before i go and beadblast it and prep it for being painted. At work we have our setup on a convayer belt, where the parts are moving at all time thru our oven. for the paint i am using and such, we will have the oven at 400 for 12 minutes... so..yes or no on being ok to paint em? wanting to take in the upper plenum, Throttlebody, and runners for the first color, and then the second color i am wanting to paint the manifold, and fuel rails.
Old Dec 11, 2003 | 12:41 AM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
yea just plug all orifices with high temp silicon plugs and tape off all machined gasket surfaces
Old Dec 12, 2003 | 07:03 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I belive I told you in anothert post also It was OK...
What do you guys powdercoat that You rdont know yourself that Alum is ok to do.. Id sujest pre-baking it 1st to outgass the alum.
Hows this Look for Powdercoating..
Old Dec 12, 2003 | 08:34 AM
LUVmy92's Avatar
Car: Camaro
Thats a nice setup , I might consider powder coating mine now. Any cons or tips I might need to know? Does everything fit back nicely?
Old Dec 12, 2003 | 01:55 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
No real cons to powdercoating. Just a much more durable type of paint really. The biggest con is stripping this ****... it's horrible.
Old Dec 12, 2003 | 03:40 PM
Kaas's Avatar
Car: 89 Iroc-Z
we do steel and such at my work....i am going to get it glass bead blasted before i take it in...and we are going to be baking it at 400 degrees for 12 minutes
Old Dec 12, 2003 | 06:11 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Matt, Invest in a 55gallon drun of Carb cleaner. Works wonders if soaked over night. or A product called DE-COAT.
Old Dec 12, 2003 | 06:15 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I undersatnd the Process. Im gust giving you heads up to PRE BAKE the part 1st.
Then Powdercoat it while Its still warm to the touch.
Then do your final cure bake
Old Dec 12, 2003 | 11:28 PM
Kaas's Avatar
Car: 89 Iroc-Z
aye, at work our parts go thru the washer, then an oven, then the paint booth then to the final oven
Old Dec 13, 2003 | 02:19 AM
Ions91Z28's Avatar
I may have to try that. I've used every type of paint stripper, and while it works for a good portion, it just can't take it all the way down in all areas. I've even tried burning the stuff off
Old May 2, 2004 | 07:37 PM
ninjairoc's Avatar
Car: 1986 Camaro IROC-Z
I'm not sure what type of gun setup you use, but if you have an electrostatic clip, where do you usually place it on an item such TPI setups, or do you attach it to metal contacting the item instead?
Old May 3, 2004 | 06:57 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I have a Rack that I hang the parts on hooks. The Rack is grounded. See the clamp in the middle grounding the rack.
Old May 3, 2004 | 02:12 PM
ninjairoc's Avatar
Looks good, thanks.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
cmichael
Exterior Parts for Sale
Dec 21, 2015 06:56 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
