Wanting to install hood locks on my car....got a question..
Old Jan 5, 2004 | 12:22 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Ok....
I might be installing a set of hood locks on my car. I painted my car about 7 months ago. If I decide to go through with this....and start to drill the holes in my hood...will my paint Spider Web? Chip? Shatter? Crack? Someone was saying to stick tape on the paint so the paint won't crack. Is this true? Anyone with any experience please post. Thanks!
Old Jan 5, 2004 | 02:06 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yup....use masking tape over the hole. Then drill a pilot hole first and then drill out the larger hole, shouldn't be a cause for concern and the pain shouldn't crack, spider web, etc.
Old Jan 5, 2004 | 10:33 AM
SpeedJunkie's Avatar
Car: 88 IROC
yeah make sure you go through every size drill bit till you get to the desired size cause that will definatly minimize the chance of any cracking. Also be careful about where exactly you want the hole to be when your done.
I think hood locks would be sweet with that hood especially if there chrome cuase it would set off the black paint.
Old Jan 5, 2004 | 11:55 AM
88txiroc's Avatar
Also, remember to use SHARP drill bits and try to have something on the underside of the hood, like a block of wood. That will help with the bit go through the hood easier. Sort of like drilling in wood, when you dont want the wood to splinter on the back side you use some sort of backer board. I hope I explained that okay.
Thomas
Old Jan 5, 2004 | 12:07 PM
Engine: 5.7
I guess I'm still having trouble seeing how the hood locks are installed. There are 4 plates....looks like they don't screw together....and it looks like in order to install these...the under side of the hood has to be flat too (for the bottom plate) I don't want hood pins...even though they have a scuff plate, the pins can still scrath the paint......I might just buy a set from Autozone, check them out......and take'em back if I don't like how they are installed. I love how you installed yours 88AZIroc, but I just want mine to me closer up to the nose, like I showed you in the picture of my brothers Z28.
Old Jan 5, 2004 | 12:11 PM
Engine: 5.7
here is where I would like to install mine:
Attached Thumbnails Wanting to install hood locks on my car....got a question..-hoodlock.jpg
Old Jan 5, 2004 | 09:21 PM
xpndbl3's Avatar
Car: 1984 Z28
i think they look better more towards the middle of the hood....like Aziroc's
i have 4 pins on my camaro i like where they're at...pics in cardomain site.
Old Jan 5, 2004 | 11:13 PM
Engine: 5.7
I'm not saying they look bad....but I think when they are closer to the SS Scoop....the locsk take away from the scoop...I like'em further away....plus you don't have to lean over the hood to unlock it....Anyways....I went ahead and bought a set today....I guess I'll just have to wait until spring to see if they will work out for me.
Old Jan 5, 2004 | 11:56 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I"d use a set of Dzus fasteners but thats me. Much cleaner install than using pins.
Kat
Old Jan 6, 2004 | 12:11 AM
MightyReapster's Avatar
Car: 92 Camaro RS
When drilling, use strips of 2" tape on your hood, use a center punch to minimize "drill walk" and use a new uni bit. I have never had it damage the paint that way.
Old Jan 6, 2004 | 12:32 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
yo, I like where you want to put them too but it seems like thats like on top of the back of your headlight. you might want to look at where you are interfering with the underpart of the hood
Old Jan 6, 2004 | 10:25 AM
Engine: 5.7
It kind of looks like that from just the crappy paint shop I did......here is exaclty where I want them....I installed a set of hood pins in my brothers 87 Z28 with no problems. (I'm going with locks though)
Old Jan 6, 2004 | 12:40 PM
xpndbl3's Avatar
Car: 1984 Z28
I STILL don't like them way out there like that. Any thoughts on whether the hood will rise up in the middle at high speeds since there isn't going to be much support in the middle.....Unless you're using the hood latch as well? Then you wouldn't need hood locks right? I'm using 4 pins since it's a lift-off style hood but they're more centered then yours, by about 6 inches towards the middle more.
Old Jan 6, 2004 | 01:04 PM
Engine: 5.7
With hood locks, the latch is required. My hood dosen't rise in the middle at highspeeds, it's more towards the sides....where the headlight pockets are....that's why I want a set of hood locks. I don't want hood pins, even though they come with the scratch plate... I could still scratch my hood with a pin. I think a key would be much safer and would look a little more smooth.
I don't care if you don't like where they are located...I just wanted to see if anyone has installed a set of hood locks out towards the front of the hood instead of more towards the middle. Also, since you have a lift off hood....your not supposed to use a latch....and I can see how you have to use 4 pins...because it's a lift off.
I checked out your site xpndbl3, where you installed your hood pins at looks pretty descent....not really that far in....do you have any pictures of the frame rail where you installed them? I'm unable to get my car out because it's like 9 degree's here and it's hibernating....haha
Old Jan 6, 2004 | 01:21 PM
F-Bodeee's Avatar
Car: 1991 Pontiac Trans Am
Transmission: Borg Warner T-5
with my hood pins, there is a hole you can already use in the engine bay......mine are in the classic position.
Attached Thumbnails Wanting to install hood locks on my car....got a question..-oldtown-0111.jpg
Old Jan 6, 2004 | 03:17 PM
Engine: 5.7
That looks pretty good....
Alot of guys just take out their rubber stop along the radiator support and just install the pin there....is that what you did? Because the location looks pretty good.
Old Jan 6, 2004 | 11:08 PM
F-Bodeee's Avatar
i didn't remove the radiator thing......there are some holes already there next to it (for what, i don't know) but i just put the pin holder things in there and screwed the nut on......then i lined up the holes in the hood (they were already there b/c i bought it from a friend). If you want, i can take a pic
Old Jan 6, 2004 | 11:19 PM
Engine: 5.7
I would appreciate it man, thanks
Old Jan 6, 2004 | 11:34 PM
F-Bodeee's Avatar
here ya go
Attached Thumbnails Wanting to install hood locks on my car....got a question..-hoodpin-004.jpg
Old Jan 6, 2004 | 11:37 PM
F-Bodeee's Avatar
another one
Attached Thumbnails Wanting to install hood locks on my car....got a question..-hoodpin-003.jpg
Old Jan 7, 2004 | 12:33 AM
xpndbl3's Avatar
Car: 1984 Z28
F-bodee.....looks like you removed the hood stoppers and installed the pins where the rubber stoppers used to be in that hole.
Old Jan 7, 2004 | 09:41 AM
F-Bodeee's Avatar
i guess a previous owner removed them b/c they were gone when i bought the car.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
