Opinions needed on my hood scoop
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Well I was wondering what you guys think of my new hood scoop. I know it still needs to be painted, but after that it should be pretty cool looking.
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Well maybe not necessary, but eventually it will be. I already had to cut a hole in the hood to clear the air cleaner and not too far down the road I'll be getting probably a 142 or 174 supercharger.
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
I think the scoop looks duller than the rest of the car. Like a flat black while the paint is glossy so they kinda clash. I think if the colors were closer it would be pretty cool.
Car: 1986 IROC-Z
Engine: 305 T.P.I.
get a ss hood, it will make your car look the same as Lock's camaro. :rockon:
you are half way their (excepet the motor).
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Do you plan on molding it into the rest of the hood?
If not, I don't like it. I don't like when people cut holes in their hood to clear some K&N air filter or something similar. Now, if you need to cut a hole to stick a blower in there, then cut away
If it was molded into the rest of the hood, it wouldn't be so bad, but I still don't care for it too much.
Just my opinion though.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
in my opinion i would have used that scoop money towards a cowl hood. i wouldn't do the whole cut a hole into your hood ******* thing. that's why i went 4inch cowl, no problems anymore with clearance and it looks much better to boot.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Originally Posted by westman
Thanks for the input guys. The scoop is a mini mopar style from Summit. I had to get something quick to cover the hole in my hood. And that was about the only one big enough to cover it. Eventually I want to get a 4 inch cowl hood.
COTM Editor
When I first saw that I thought that look like something ou would see on a primered up old duster or something. Now I know that it is! The rest of your car looks beautiful, nice work. Try harder on the hood you'll come up with something better.
ElPaleterro85
Aug 13, 2015 03:49 PM
