painting brakes?
Car: 1983 Z28
Transmission: TH350
painting brakes?
has anyone painted there calapers (sp?) if so can u post a pic for me. does it last? what paint did u use? how did u paint them? (while on or off) is it hard??
also i just got new silver drums should i just leave them silver or pain it the same as the calapers??
I painted my calipers red and drums black. I used High Temp engine paint and it turned out pretty good. The red gets really dusty from the brake dust so I have to keep cleaning them and repainting them.
Whatever you do don't paint the drums a color. It just looks wrong and in my opinion looks horriable.
Sean
Sean
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
I used a metallic silver wheel paint. It would have been best to remove the caliper but I just masked the heck out of everything. They've kept their finish VERY well and look aluminum. I painted all four and they look excellent. Hopefully the front will be seeing some upgrades though
Painting drums semi-gloss black is about all that's tollerable, if I see one more set of red or yellow drums I'll snap.
Painting drums semi-gloss black is about all that's tollerable, if I see one more set of red or yellow drums I'll snap. Joined: Aug 1999
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
When I painted my calipers, I also painted the hubs of the rotors the same metallic color so they matched the calipers. I hate rust and like everything to look nice and clean.
I used some POR 15 high temp paint. I dont think you need high temp paint and probably wouldnt use it again because most of it doesnt fully cure until it reaches like 350 degrees F and if you wipe you finger on the caliper hard enough the paint comes off a bit.
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
i painted my drums but haven't got around to the front.
This is what i did
1) I picked up some grease lighting degreaser, a wire brush and some high temp engine paint all from autozone.
2) I took of my wheels one at a time and sprayed degreaser on it and let in sit for 5mins.
3) I then took the wire brush and scraped any loose dirt or rust.
4) After I did all that I rinsed them of and took a hairdryer to them.
5) Finally I sprayed the paint from about 6 inchs away paying attention to what I hit. (It's not to important if u miss a little bit the wheels cover alot).
Let us now how thet turn out post pics if you can.
This is what i did
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
man im in the process of painting my wheel wells and polishing my chrome again (TONS of over spray almost ruined my rims) and i just hit the calipers up with some red cheap spray paint. didnt mask anything but didnt get any paint on my rotor and cleaned my rotor off excessivly with brake cleaner afterwards. just needed somethin to break it up back there. looks good still tho, ill get some pics hopefully soon.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm really thinking about painting my calipers too...not sure what color though....either black or aluminum.....??
Car: 1991 Z28
Engine: 383
man i just went out to look at my car and the red calipers look awesome. i higjly recommend this gets done. done touch the drums tho.......only black!
Car: 1990 Iroc-Z
Engine: 350 L31 Vortec
Here is what some local guys have done. i have not done anything to mine just yet. waiting to get new brake pads and also to get my rear disc brake setup.
http://www.ws6zxr.com/showthread.php?s=&threadid=29373
Some General info: http://www.ws6zxr.com/showthread.php...ht=Brake+paint
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I really want to paint my calipers Prowler Orange. I have some paint, but it really won't work. I wonder if there is a primer or overcoat I could put on the paint to stop it from burning off.
Street Lethal
Apr 30, 2019 12:14 PM
