Is there anyway to make the 91-92 tails look like this ?
Old Mar 16, 2004 | 11:58 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
at night ..all red and all lighten up
i made a quick photoshop
Attached Thumbnails Is there anyway to make the 91-92 tails look like this ?-ph3.jpg
Old Mar 16, 2004 | 12:40 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
yes, summit sells this spray by vht i think its called translucent candy apple red or something similar which is translucent to light and gets rid of that ugly amber color.
Old Mar 16, 2004 | 12:45 PM
Calderone's Avatar
Car: 87 Vette
oHH cool
The wiring is eatcake ! ..so the idea is to make it look
like the 85-90 trans am tail but with this killer 2 piece lights
but the amber was my doubt ...
im sure it can be done flawlessly
Old Mar 16, 2004 | 01:46 PM
nikh23's Avatar
ooooooooooh my fault, i didn't realize that you wanted all three panels to light up red, my mistake. anyways yea i'm assumign it can't be all too difficult but i'm not sure how you'd use them as blinkers as well?
Old Mar 16, 2004 | 01:48 PM
Calderone's Avatar
Car: 87 Vette
easy
with the 82-84 Birds'n' T/A and 85-90 T/A only wiring !
Old Mar 17, 2004 | 09:08 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
All you would need to do is add a bulb wired off of the running lights and inserted into the outer lens.
I did this on my Formula when I had the 85-90 T/A lights on the car.
This is how the formula was when wired up with the T/A lights.
parking lights,
Left turn signal
I didn't like it that much so I drilled a small hole into the outer lens area and used a small socket and wired up to the running light wires that werent used with the T/A lights.
When I put these lights on, I just removed the extra bulb wiring I added,
Old Mar 17, 2004 | 09:36 AM
Calderone's Avatar
Car: 87 Vette
Hey
Zepher ...
but it doesn's lit all the red at night ?
take a look at the pic i posted ..
i wanted to look like that when running...
but when you brake ...
only corner sections blink
i made that with my 82
converted to 85-90 base bird lites
running :
Attached Thumbnails Is there anyway to make the 91-92 tails look like this ?-8.jpg
Old Mar 17, 2004 | 09:40 AM
Calderone's Avatar
Car: 87 Vette
braking
braking
Attached Thumbnails Is there anyway to make the 91-92 tails look like this ?-5.jpg
Old Mar 17, 2004 | 10:09 AM
Zepher's Avatar
Re: Hey
Originally posted by sammycalderon
Zepher ...
Well, I didn't take a picture of the lights after I did the mod. Those pics were taken right after I installed the lights.
Old Mar 17, 2004 | 09:30 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
if u wanted the effect of all lights lighting up when braking or all lights on each side for its respective turn signal, u can buy a wiring converter from various places that are meant for trailers, that convert the newer seperate turn signals into older brake/turn/tail all-in-one style
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
silverstang84
Exterior Parts Wanted
Sep 21, 2015 08:05 AM
LilHot
Aug 19, 2015 10:02 AM
