I took out the heat and A/C.....pics
Old Mar 24, 2004 | 03:42 PM
F-Bodeee's Avatar
Car: 1991 Pontiac Trans Am
Transmission: Borg Warner T-5
It looks way better considering neither worked or were connected.
Before:
Attached Thumbnails I took out the heat and A/C.....pics-ac-002.jpg
Old Mar 24, 2004 | 03:44 PM
F-Bodeee's Avatar
after:
Attached Thumbnails I took out the heat and A/C.....pics-engine-002.jpg
Old Mar 24, 2004 | 04:31 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i would get an a/c delete box if i were you...even if you heater doesn't exist, it will make the car look much more complete than a piece of aluminum over the holes.
Old Mar 24, 2004 | 06:56 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
i need one, where can i get one....ive been lookin all over the place, and gm dont have them
Old Mar 24, 2004 | 07:17 PM
V6camaroman's Avatar
try the junk yards on the earlyer model thirdgens 82-84. everyone says they are hard to find. i have 4 non ac heater boxes
Old Mar 24, 2004 | 07:47 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Id do the sheet metal thing. Paint it - it looks just fine, better then an AC delete box IMO
Old Mar 24, 2004 | 09:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i went with the AC delete box and i was happy with it....not to mention that having a defroster helps on the humid friday nights when i'm cruisin
Old Mar 24, 2004 | 09:36 PM
formul8!!'s Avatar
Car: 2004 GTO
Cruise your local junk yards or spend the cash and get the A/C delete box from ebay. You will need heat when your windows fog up.
Attached Thumbnails I took out the heat and A/C.....pics-delete-box-pic.jpg
Old Mar 25, 2004 | 08:54 AM
F-Bodeee's Avatar
sorry, no a/c delete box for me......i live in Florida so no heat needed and my a/c consists of TTops and power windows.
Old Mar 25, 2004 | 03:28 PM
MCas7's Avatar
I have an AC delete box if you are interested. I removed the heat and AC too but I just covered up the the holes with sheet metal.
Attached Thumbnails I took out the heat and A/C.....pics-camaro-5a.jpg
Old Mar 25, 2004 | 06:15 PM
Charged350's Avatar
Car: 87 IROC Z28
yeah, how much, yeah, u got a PM
Old Mar 25, 2004 | 06:19 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
dude, how'd you get the heater box out? i got all of my top screws out, i dont know if there are some on the bottom?
Old Mar 25, 2004 | 06:25 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
There are several bolts that go through from the inside of the car into the heater box. You'll need to take the passenger side under-dash trim off and then pull back the carpet and find the bolts. Sorry I can't be more specific, but once you get under the dash and start looking around you should be able to find them without much trouble at all. Good luck!
-Paul
Old Mar 25, 2004 | 09:39 PM
nolanr0413's Avatar
Car: Trans am
it really frees up some space when you take that stuff out.
Old Mar 25, 2004 | 09:52 PM
Engine: carbed L98
yeah thats why im doing it. i even thought about making my own heater fan...i can get some fairly powerful 12v DC fans that blow a good 200 cfm i think. make a small housing to put it in and hook up a switch to it...and just close off the AC hole
Old Mar 26, 2004 | 03:55 PM
SNIPING92BIRD's Avatar
Car: 1989 GTA / 92 Z28
Engine: 350ci
Transmission: 5 speed
i got all of that removed as well only didnt really think of the windows fogging up till now someone mentioned it ...completely forgot about that...oh and speaking of living in FL...rains quite often...and having them T-Tops off with windows open an a sunny summer day aint always so great specially here in South Fl...
Old Mar 26, 2004 | 04:02 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I have a small elec. heater that plugs in the cig. lighter that I can throw on the dash for that..... works great
Old Mar 26, 2004 | 04:05 PM
Engine: 350ci
good idea...i need one of those too...
Old Mar 26, 2004 | 07:12 PM
Charged350's Avatar
Car: 87 IROC Z28
there is 3 bolts from the inside, 10mm socket and it comes out...
Old Mar 28, 2004 | 01:13 AM
MdFormula350's Avatar
even deleteing a/c and keeping heat saves so much space its well worth it.
looks good.
Old Mar 28, 2004 | 12:31 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Man, only if i didnt live in texas...
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
