Projector Headlights, any good?
Old Apr 15, 2004 | 10:54 AM
Z06's Avatar
Z06
Check out this Link, http://matrixracing.com/BI4364Details.htm
I allready have the H4 conversion headlights, but these look alot nicer. Has anyone tried them? Just wondering because my H4 headlights give me pretty damn good lighting at night & don't want to change it for lesser performing lighting. The price also sucks!!!!!!! But does look nice.
Old Apr 15, 2004 | 05:30 PM
TwinTurboROC's Avatar
ill tell u this weekkend when mine are on
Attached Thumbnails Projector Headlights, any good?-low-beam-projectors-1
Old Apr 15, 2004 | 05:32 PM
and yes everything there is from matrix
Old Apr 15, 2004 | 06:01 PM
CaysE's Avatar
Man I wish you would show us your car.
Old Apr 15, 2004 | 06:49 PM
Mr. Z06's Avatar
Damn...those are kewl.
TwinturboRoc, are you going to replace all 4 lights
with projectors?
I have the H4 conversion on my car currently, but have always wanted true HID.
Now, I can buy this kit, and get some used Xenon Ballasts and Xenon bulbs and I will be set.
Tommy
Old Apr 15, 2004 | 07:49 PM
Dude im in love with your car... wow a clean unhit black car... man what i wouldnt do for that chassis... some day
no the projectors are going on as the low beams and te clear ones are going on as the high's.... depending on the light out put i might swap em around... ill just swap plugs from inner to outer to check... but i definately want the projectors as the lows/outer... also im doing clear signal lamps... i definately post some befor after and comparison shots...
some ?
what kinda drop is that looks intrax, maybe even a few choped off coils.... dam that thing is clean.... think im gonna use ur car as background for my pc. .....
as to the hid's eventualy when i get something like yours... clean straight and pretty... ill come up with something... or get the Xenarc HID from sylvania... probably come up with something, usualy works out cheaper...
Old Apr 15, 2004 | 07:52 PM
thats a vert.... beyond sweet
Old Apr 15, 2004 | 08:13 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
TwinTurboRoc what are you using for your highs are those H7 bulbs? and what kind of encosures for your highs?
Old Apr 15, 2004 | 09:57 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I bought those headlights awhile ago for my 91 ta bird. You just have to make sure you put them in right side up and on the correct side or else the beam pattern is all screwy. Looks pretty cool though. I really want to get rid of my popups for some fixed HID projectors with body coloured molded fiberglass covers.
Old Apr 15, 2004 | 10:59 PM
CrazyHawaiian's Avatar
Car: too many ...
Looks like the best 4x6 HID friendly replacement headlamp parts I've seen. Most of them dont come with a glass lense. Let us know how it turns out for you. Oh yeah, nice Vert!!!
Old Apr 15, 2004 | 11:18 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Want to save some money? These come with bulbs too. Blue sh*tty bulbs, but bulbs none the less.
EDIT: Glass faces and metal backing pieces.
Old Apr 15, 2004 | 11:32 PM
ultra high wattage h4's 100w (these are advertised ratings) lows thru projectors fed by 10 gage relayed harness 120w (these are advertised ratings) thru the same for high's... sunday ill be putting em in... maybe tommorow evning ill get the lows in.... ill get better pics, most of mine are take with a digital camcorder with like 1.5-2 megapixel range... not the best but good enough... ill get some high quality pics and some detailed explinations... but the tech article is good enough.... you know those tech articles should have links to their respective sections on the boards... cause it seems that ALOT of people overlook them.
Old Apr 15, 2004 | 11:35 PM
Shawn ill take some close up pics of the hosing and post em for you, im not sure but i think lexus makes a h4 style HID bulb (A REAL HID BULB) that fits in these housings... not too sure ill check up on em an let ya know unless you got something figured out... i remember something about bmw HID's but can recall
Old Apr 16, 2004 | 12:13 AM
Car: too many ...
Thanks! Would like to see some closeups. Yes you can retrofit the Lexus HID's into your car and probably save some $$. I think they started becomming an option in 98 and up models (GS, LS, SC, etc). Make sure to get the ballasts too.
Old Apr 16, 2004 | 12:37 AM
i might do that at a later date... will update on sunday or tommrow evening
Old Apr 16, 2004 | 01:02 AM
Mr. Z06's Avatar
Twinturboroc,
The springs are from Globalwest (cut 2.5 springs).
Tommy
Old Apr 16, 2004 | 11:04 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
The problem with those "projector" headlight conversions is they lens itself isn't sealed. It's just the lens sitting inside the whole housing. There isn't anything surrounding the bulb forcing the light to just exit through the projector lens. So you're going to get ALOT of glare and weird reflection if you just stick an HID bulb in there. If you want really nice cutoff lines and good looking install you need to mount some actual projectors from those cars in these housings. If you really had some cash you could go with four bi-xenon projectors and get highs/lows coming from all the lights.
Old Apr 18, 2004 | 12:04 AM
yes to the HID.... but **** im still gonna try.... here are some updated pics... factory wiring non aimed.... there pretty good, probably just as much output as the regular sealed beam... doesnt have that anyone dark blue ting.... got a nice light blueish white tint to the light.... sunday the new upgraded harness should be in, 10 gauged relayed, fused in h4 specific connectors... pics of that to follow
Old Apr 18, 2004 | 12:07 AM
if things dont work out great i might swithch the housings around projectors on the inside... when the high beams are on the spread of light is amazing.... and i think the nicest part of the whole thing so far it doesnt have that HID cut off line with the light beam... thats the part that annoys people, that sharp cutoff of the light beam... well will post more pics come sunday
Old Apr 20, 2004 | 02:10 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Any pics from a few steps back? Looks pretty good. I was interested in the projectors at first, but don't reall like the circle in the square look
Old Apr 20, 2004 | 06:40 PM
ill get some night pics and a whole car shot... im gonna have to edit the whole car shot to not include some things i dont want people to see, but nothing concernign the lights... im also in the process of making clear signal housings...
Ghettobird52
Jul 5, 2024 11:18 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Zachattack0925
Aug 12, 2015 09:52 PM
