should i lower?how much?
Old Apr 17, 2004 | 01:06 AM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
do u think it should be lowered? how much?
Old Apr 17, 2004 | 01:48 AM
Graboid's Avatar
2 inch (at least)
Old Apr 17, 2004 | 09:22 AM
rusty rider's Avatar
Car: 86 IROC
Engine: 305 lg4
It deffinatly needs to come down a little.
Old Apr 17, 2004 | 09:56 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Any kit will look good. The least amount of lowering springs out there are usually 1". They can go from 1.3" to 2" after that. I would consider the Prokit or Sportlines.
Old Apr 17, 2004 | 09:53 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
i'd say at least 2"
Old Apr 17, 2004 | 10:29 PM
CaysE's Avatar
1"
Old Apr 17, 2004 | 10:45 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Compromise- 1.5"
It could use a lower stance, in my opinion. It's sitting a little high.
Old Apr 17, 2004 | 11:34 PM
Car: 1983 Z28
Transmission: TH350
ya i know its to high now and has a to much of a space between the tire and wheel well. i think i am going to go 1.5" is there lowering springs that will give me a soft ride and good handling???if possible i would like to avoid the harsher ride.
Old Apr 18, 2004 | 12:54 PM
Metal383's Avatar
Car: 84 T/A 70 Chevelle SS 78 T/A
Engine: chevy 383 Chevy 496 Pontiac 462
Transmission: built THM700r4 Richmond 6 built TH400
1.5 would be too much around here, an inch is the most I'd do as far as speedbumps, driveways, etc.
Old Apr 18, 2004 | 04:52 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
I would put ground effects on it, they make it look alot lower and you don't have to go through the inconvience of having a lowered car.
Old Apr 18, 2004 | 05:11 PM
Car: 1983 Z28
Transmission: TH350
there is ground fx on the car
Old Apr 18, 2004 | 05:18 PM
Car: 1983 Z28
Transmission: TH350
see..oh ya thank for the info i am going to go 1" then i dont wanna be mashing the floor. so i am guess there is no lowering spring that could give me the same comfort as stock one do??
Old Apr 18, 2004 | 06:23 PM
Metal383's Avatar
maybe there are, my hotchkis springs seem to have a stiffer rate.
Old Apr 18, 2004 | 08:39 PM
FLYNLOW92rs's Avatar
I'll chime in a little late, but i vote 1-2"
Old Apr 19, 2004 | 11:23 AM
CaysE's Avatar
i win!
Go with Eibach Prokits, they're a 1" drop, maybe a bit more in front.
Old Apr 19, 2004 | 02:44 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Oh, sorry bout that, its hard to tell from the original pic. Is there a front spoiler on there too? If not you should put one on.
You should try the Edlebrock Eibach Sportline springs. They are stiffer than the stock, but they are prgressively wound so normal driving comfort is maintained.
Old Apr 19, 2004 | 03:28 PM
CaysE's Avatar
The Sportlines give too much of a drop though. Go with the Pro-Kits.
And what's this Edelbrock crap?
Old Apr 19, 2004 | 04:56 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
The sportlines only drop it 1.5 inches in the rear and 1.75 in the front.
Eldelbrock uses Eibach springs. When you buy an Edelbrock spring kit your actually buying Eibach springs.
Old Apr 21, 2004 | 08:29 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
2"
And this is right after changing the springs. They have dropped a little bit more, but they are almost there. Great springs.
Old Apr 22, 2004 | 10:01 AM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
well, you could also get 91-92 ground effects, that would make it look lower, since them ground effects are not as low.
That or I would say, 2" if your not running super low exhaust, if you are (like me) then no more than 1" if any.
I loke lowered 3rd gens a lot, however, I run true dual with an X pipe and if I lower the car at all from stock height, I will scrape just driving down a flat road. My car sits great to me, it's got the 91 ground effects, 17" ROH wheels with the 45 series tires. I like it, however, if I did not run this exhaust set up, I would go 2" no doubt.
You do good with 2" with them ground effects...
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
