tailight blackouts...again
Old Apr 18, 2004 | 06:37 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
well i have some free time to put some things on that i have and i want to finally mount these blackouts. my question is can i apply heat to this "plastic" and be able to bend the edge? the problem is that they are about 2" to long and extend over the licsence plate area. it this plastic bendable with heat or should i just cut the edge off? here is a pic of the problem area.
Old Apr 18, 2004 | 06:52 PM
benoit454's Avatar
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
who made thoose? gts or wade or ventshades or whom?
I think you could heat em w/ propane torch and lay em on somthing firm and rol em over. or cut em off.
Old Apr 18, 2004 | 07:11 PM
dsaint1347's Avatar
Cut them off with a plexiglass knife, or have a pro do it.
Old Apr 18, 2004 | 07:15 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
i believe these are a really old gts style. i bought them off a guy that said they were bought for an 84 and i assumed all thirdgen camaro taillights were the same length. i guess i was wrong but i got them cheap.
so you dont think i could bend them? can i take a dremel to them with a cut off disk? do these plastics crack easily?
Old Apr 18, 2004 | 11:39 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
they used to come with a license plate cover, so you had a full band of black out across the back, like a '81 Trans Am
Old Apr 18, 2004 | 11:46 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
just cut it, and then sand to make smooth edges
cheers
blake
Old Apr 19, 2004 | 01:09 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
They don't crack to easy. They are similar to Lexan, which is extremely flexable and impact resistant. Take a peice of 2" masking tape and cover the areas inside and out you plan to cut (to protect from scatches), mark your cut, make the cut, and finally sand smooth.
Old Apr 19, 2004 | 09:49 AM
benoit454's Avatar
Car: 86 camaro
I've seen plexi bent before. You would need something to form it around like a mold or a 2x4 and a heat gun I've seen used gotta keep the heat moving and try to bend it easily but it could crack or break so cutting em might be the best bet.
Old Apr 19, 2004 | 10:21 AM
FlyinLow89's Avatar
Car: 1995 Formula/2001 GTP
Engine: 5.7 LT1/3.8 Supercharged
Dont heat it up, it will ruin the finish in that area. it will become foggy and un smooth. you should be ok to cut it and then use a long file to make sure its all nice straight then sand it down for a nice finish (only the edge)
Old Apr 19, 2004 | 11:13 AM
benoit454's Avatar
Car: 86 camaro
I was telling him how to bend it because that's what he originally posted about if he could bend it around so I told him the options since no one else would they'd only say cut it off which is also what i said was his best bet unless he wants to chance heating it up.
Old Apr 19, 2004 | 11:36 AM
FlyinLow89's Avatar
well i wasnt posting in reference to what you said. I was just telling him not too. Im not out to get you
Old Apr 19, 2004 | 11:53 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
I don't see bending them as a alternative. They have a lip that rolls underneath of them, and that would distort if he trys to heat and roll them.
Old Apr 19, 2004 | 12:21 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
thanks guys. i guess i will just cut them.
Old Apr 19, 2004 | 07:46 PM
benoit454's Avatar
Car: 86 camaro
lol it's cool man.
I love the look of the licsense plate cover and al so its black all the way across but i couldn't do it to mine we have rear plates here and it wouldn't work we don't have to have fronts but I think they'd gimme hell over having em on front and not back and if I had the solid cover I'd have find a new place out back to mount mine.
Old Apr 19, 2004 | 09:55 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
well i was thinking of getting some clear plexi and connecting them to make a full cover but its not worth it. i will just cut them.
Frozer!!!
Jan 19, 2024 04:55 PM
90formulaVortec
Sep 7, 2015 06:54 PM
Jono
Aug 30, 2001 06:20 PM
zupmanZ28
Jul 21, 2001 09:07 PM
CDnAP48
Jun 25, 2001 06:18 AM
