How to clean engines????
Old Jun 8, 2004 | 01:56 AM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
How the hell do i clean my engine(lu5 crossfire).The first time I bought a orange can at auto zone engine degreaser smelled like gas.And it didn't do much i followed the directions and sprayed it with a water hose but still looks bad.Then just last week i used greased lightning and it worked alittle I saw some grease oil residue come off but still not what i wanted any idea i have portable steam cleaner I'm gonna use if i remember correctly this is the same method auto detailers use right? Any help would be great.
Old Jun 8, 2004 | 05:46 AM
1gta2c's Avatar
Try Castrol super clean. This stuff rocks! just don't leave it sitting on plastic parts too long.
Old Jun 8, 2004 | 05:26 PM
CaysE's Avatar
Engine degreaser and a power washer. Take off the plastic parts and wash them with mild soapy water. Finish up with plastic polish or the simple Turtle Wax Formula spray and a rag method. Nice!
Old Jun 8, 2004 | 05:54 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
some heavy dute brake dust cleaner and a pressure hose , i wouldnt recomend you using the brake dust cleaner all the time, i say just use it once to get all the nasty gunk you cant get off with a regular can cleaner, then after that you can start using the cans to keep it clean
Old Jun 8, 2004 | 07:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Carb cleaner (spray can type) works great on fuel and oil stains, like on an aluminum intake.
Old Jun 8, 2004 | 08:01 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Fast Orange. It works just as well on engines and engines bays as it does your hands.
Old Jun 8, 2004 | 09:15 PM
Car: 1990 firebird
Engine: 3.1 v6
dammit i knew there was someone out there that would use that , i always think hm i should clean my engine bay with this stuff when i use it for my hands, gota try that one, maybe its not as harmful on paint
Old Jun 8, 2004 | 09:35 PM
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
For the engine bay it is fine, just be gentle. It might cause a few small scratches here and there. But as long as you are only using it in your engine bay on not like.. On the hood, you should be ok.
But yes. It is amazing
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
