Polished camaro wheels (Before, during, after)
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
looks good
i would paint where the lugs go with black like it was stock since it is an area that does not polish well.
you may get a better shine still yet with some white rouge and a die grinder buff attachement. you can get them from eastwood.
http://www.eastwoodco.com/
did you use power tools or just the mothers by hand?
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 700 R4
Yeah i think that i will paint where the lugs go black. never really thought of that before.
I used a dremel for the little cracks and corners and sanded the rest. My hands are still recovering, unfortunatly i still have 3 to go
I just buffed it by hand with mothers but i will probably use my buddies buffer on it
Engine: 305 tpi LB9
you can get buffs that fit on the dremel. i got sanding stuff for it too. check out that link look at all the neat junk they have to save you fingers. i haven't done my wheels yet but i did complete all the other goodies, tpi runners plenum tail lights altinator. i beleve the sanding stuff is called spiral, adn cone sanders. all you need is the srbor and away you go. get two they bend, don't want to sand with a bent arbor or you will have to sand agagin.
Jeff
Jeff
Car: 1987 Z/28
dam that looks really nice!! how many hours did u put into that one rim?
and what did u use to take the first lair of paint/clear coat off?
all probaly polish my wheels soon to i hope
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Lookin good man! Polishing is a pain but it really pays off. 10 hours is nothing... I know I spent atleast double that on my first couple.. but I had to tape off for paint and everything too. Keep up the good work, post some pics when you get em on your car!
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Originally posted by Burn EM!
Ok, So can i do this to my IROC wheels? Or do they have to be special..........
Exelent Job man.
Exelent Job man.
https://www.thirdgen.org/techbb2/sho...hreadid=189570
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
i like it with the center painted black, those rims are so plain they need something. Looking awesome now have fun with the other 3.
Engine: L98, Hemi 6.2
all of us will do anythin for money
! Man u did a fantastic job, u cant get any better then that, thats prob better then the factory, good job Supreme Member
Car: 88 Camaro
Engine: L98 350
Think I'd polish down in the spokes and the outer edges, then sand and paint the open sides with some darker metallic grey, about like the 16 inch IROC wheels. Paint the center area like you did. Level of difficulty is way to high for the whole wheel, but it does look darn good.
Car: 1988 Chevrolet Camaro Iroc Z28
Engine: 5.7 liter TPI L98
Transmission: TH- 400
polished and painted irocs
Heres mine I srtipped them with tal strip 2 for aluminum surfaces. I sanded from 320 400 600 dry then 800 1000 1500 2000 wet. Polished with mothers,masked off and painted inserts with high temp silver engine paint. Did it all by hand because all the tools I had tried left machine marks even on low. They look real good right after you polish them but I need some zoops sealent or something. I started to clearcoat and got one done, let it dry for about 2 days it made them much duller. I had to strip it all over.So these are bare polished aluminum 88 Iroc wheels
kah992
Aug 19, 2015 02:55 PM
