candy blue?
Old Jul 30, 2004 | 10:39 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
candy blue?
can i get some pics of candy blue and a paint code,thanx.
Old Jul 30, 2004 | 10:44 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
in about 10 days i can show ya the car as i am doing a 3 stage candy paint job righ now. last primer this weekend and paint next.
candy cobalt blue.
jeff
Old Jul 31, 2004 | 03:02 AM
Kandied91z's Avatar
their are no paint codes for a candy color, you can get paint that is candy and add your own number of layers to change the color to your choice.
mine is a 5 stage candy with 6 level red clear and blue pearl.
here is a picture of what blue candy would look like..
Old Jul 31, 2004 | 05:29 PM
JeffW's Avatar
Engine: 305 tpi LB9
you can look in the body board i shot a test panle today,
here is a quick look at candy cobalt blue over oriental blue base.
i did the panle with 2 diffrent bases to see the diffrence, on side my base other side was just the metralic primer. now this is a test panel not part of my car so don;t gripe about the eyes and orange peel.
Old Jul 31, 2004 | 05:30 PM
JeffW's Avatar
Engine: 305 tpi LB9
here one with only a couple coats of the candy on it, it gets darker and more purple with each coat.
Old Jul 31, 2004 | 07:15 PM
Kandied91z's Avatar
looks good, my vote is on the left. candy fades over time...go slightly darker and the color will last alot longer.
Old Jul 31, 2004 | 07:27 PM
JeffW's Avatar
Engine: 305 tpi LB9
thanks, the left is actully what i am doing. i was told candy is hard to shoot over light colors so i wanted to try it and see how i could mess it up just a learning process thing. man they were right it is hard to shoot on lights. the left is oriental blue under the candy much easier to cover without lines or blotches.
Old Jul 31, 2004 | 07:30 PM
Kandied91z's Avatar
what are you using for a base? using a blue base sounds odd with a blue candy...
try shooting the blue over a dark gold metallic if you want real depth. candies are typically either gold or silver base. if you are using a color while i suppose could be considered candy since you are layering it is really just another tristage metallic.
Old Jul 31, 2004 | 08:02 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
HOK
UK5 over BC02
Orion Silver Base Cobalt Blue kandy..
I'll get around to it one of these damm days. I primed My 8point roll bar today. hopefully 2morrow I shoot it in a Metalic Dark Grey. to mikda blend in with a Black/grey Int.
Old Jul 31, 2004 | 08:18 PM
JeffW's Avatar
Engine: 305 tpi LB9
im using metalic strato blue base with the uk candy. the hok book shows all the variation of cobalt blue candy over diffrent bases to get diffrent colors. i prefered the darker base since it makes shooting the candy more forgiving for a novice. if i could really really paint i would of went with a silver or gold base but it is not for the novice. the fender i showed has silver metalic primer on the right side. and i could see spolitches and lines where i did not folllow that gun properly. but then again i was 1/2 kneeling in the drive with the fender against a rim.
where did i come up with oriental its strato i think oriental was my first choice then decided on darker
JeffW's Avatar
Engine: 305 tpi LB9
here is the base coat
Old Jul 31, 2004 | 08:39 PM
JeffW's Avatar
Engine: 305 tpi LB9
here is what it looks like up close under good light it was cloudy when i took the other pics. still not the best pic but you can see the flake in it.
Old Aug 1, 2004 | 12:48 AM
Kandied91z's Avatar
i agree with the novice thing, sounds like you've researched a bit which is great. just take your time and layer evenly. prep is really the most important part of the job but with a good prep and a steady hand i'm sure it will turn out beautiful....i look forward to seeing it.
Old Aug 1, 2004 | 01:04 AM
Irhal's Avatar
Car: 94 Firebird
Engine: 3.4L
Transmission: t5
I intent on going a bit less extreme then a candy coloured paint but I will be shooting my t/a with a three coat white perl ( GM #93) and I never did that before.. but the principle is the same as a candy colour... how do you go with the clear coats over the base? you shoot those layers the same way you would a normal clear or is there any hidden trick to it?
Old Aug 1, 2004 | 08:06 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Pic's dont do the chips justice nor do pictures of cars with HOK candies.
The UK5 over BC02 I plan to do is the closest match to the Grand Sport Vette Dk. Cloission. (ademeral blue)
Keep up the good work and deff post more pic's
Old Aug 1, 2004 | 09:30 AM
JeffW's Avatar
Engine: 305 tpi LB9
that is what i am doing except bc 04 base with the uk04 cobalt candy. the hard parts is since the candy is basicaly a tinted clear each stroke of the gun has to have a 75% overlap and you have to walk the entire car with each pass. you can not panel paint or go over it if you botch it. if there is a run or sag or heavy spot it will show in the final product. that is why i am using the darker base covers a little easier the tint of the candy will be a slower process as far as effect.
look at the kbc line of hok. i was told it is real close effect of doing 3 stage candy but much easier to shoot. I will let you all know how it comes out and if its as hard as they all say. i'll be using the kbc on my pickup to see what the diffrence is. or i will be using the kbc if i botch this job all up. i think it will be fine though.
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
