Show pics of thirdgen with BMW-rims
Old Sep 18, 2004 | 04:56 AM
René Vlietstra's Avatar
I'm looking into soms bigger (18- 19") rims. Since I livein Europe most of the wheels you use like AR, Boyds etc. are very expensive.
BMW (replica) rims are cheap over here, but I haven't seen much pics of them on thirdgens, so please show me some...
Old Sep 18, 2004 | 07:33 AM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
I'm live in Taiwan, some problem, it is very very expensive if I buy the rim from US, there are a lot BMW rim, there is the recently picture, it is BMW M5 replica in 18's, much cheaper, sorry about the pic, other picture are too big to attach.
Old Sep 18, 2004 | 07:38 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
the one I posted before, I took it off now....
joekickass's Avatar
Engine: 2.8
Transmission: auto
sorry, forgot the pic.....
Old Sep 18, 2004 | 11:06 AM
I'm thinking of these, any comments about how they would look on a thirdgen??
Old Sep 18, 2004 | 11:09 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
hey rene
hey rene !
they would look KILLER !
Old Sep 18, 2004 | 11:36 AM
I photoshopped them (quick and dirty) on my vert. They are 18x8,5 in front and 18X9,5 in the back. They are AC schnitzer replica's
Old Sep 18, 2004 | 11:54 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
BMW wheels fit third gen cars?!?!?
Please help with more info -- size, offset, etc.
Thanks,
Jason
Old Sep 18, 2004 | 11:56 AM
PontiacRacing's Avatar
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
Yes, please post more info. I had heard this before, but only sketchy details.
Old Sep 18, 2004 | 12:01 PM
The lugnut pattern of BMW-wheels is almost the same , it's 5x120mm (5X 4,75"= 5X120,6 so there is only o,6 mm difference)
The BMW, 5,6 and 7 serie wheels often fit well. 3 series wheels often have a big positive offsett, so you would have to use spacers to fit them right.
But that's not the way I want to go. Either they fit right or they don't fit, no messing around with spacers for me........
Old Sep 18, 2004 | 12:05 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
So if you get them mounted hubcentric as opposed to lug-centric you can make up the difference.
There are more folks making BMW wheels than Camaro wheels, and with more interesting styles. I kind of like that idea...
Jason
joekickass's Avatar
Engine: 2.8
Transmission: auto
they can fit, check the 5/7 series rim..
Old Sep 18, 2004 | 01:13 PM
BirdsofPray's Avatar
Car: 1991 Z28
I agree....my interest is definitely piqued. Especially since the photoshop Rene did looks absolutely gorgeous.
Old Sep 18, 2004 | 01:20 PM
LaxStreetRacer's Avatar
Car: 91 Z28
In the second pick of the black car, what are those rims that kinda look like z06's??
Old Sep 18, 2004 | 01:22 PM
Those photoshopped wheels look sweet. So 5 and 7 series wheels fit for sure?
Old Sep 18, 2004 | 01:44 PM
joekickass's Avatar
Engine: 2.8
Transmission: auto
they are BMW AC style, I had try 2 18's BMW rim, the offset is about 15mm, 8.5J, only one problem.....check the pic I attached, some of the BMW may have bigger center hole than thirdgen stock's, so the rim will not stay on the bolt well, you will need a custom center ring to clean the different, I did that for the rim in the second pic but the rim in the first pic just fit well ...
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
those are AC schnitzer replicas as well
Old Sep 18, 2004 | 02:47 PM
You'll always have to check the offset/backspacing. There are 5 and 7 series wheels with to much positive offset to fit right. You'll have to measure it to be sure.
Old Sep 18, 2004 | 03:43 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
custom center ring = hub centric mounting
Jason
Old Sep 18, 2004 | 03:58 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I would LOVE to fit some classic style BBS wheels. The only challengs is that they only go up to 8.5" width...
Jason
Old Sep 18, 2004 | 10:52 PM
joekickass's Avatar
Engine: 2.8
Transmission: auto
BMW replica rim are almost 8.5J front and rear, that sucks, too wide in the front and too narrow in the rear (in 18's)
Old Sep 19, 2004 | 01:12 AM
Excuse my ignorance, but I don't understand the whole offset thing.
Old Sep 19, 2004 | 01:53 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
BMW 5/7 series rim are about +13mm offset, it is very close to thirdgen, I had asking about the offset of thirdgen stock but no reply, all I sure is the BMW rim look fine on car (about the offset), there is a formula to calculate the back spacing of thirdgen, about that, it show I will need a 3mm spacer on the front wheel if I go 18's, 13mm offset, 8.5J, the rear wheel need no spacer...., in my case, I didn't use any spacer now....
Old Sep 19, 2004 | 02:30 AM
read all about offset and backspacing at:
http://www.skulte.com/adapterfaq.html
Old Sep 19, 2004 | 08:25 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Search for Rondell wheels on EBay and you'll find some sets in 17X8 fronts and 17X10 rears, or 18X8 fronts and 18X10 rears. A bit expensive, but would be very well worth it for such nice looking wheels. You gotta pay to play!!!
Old Sep 19, 2004 | 09:07 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
At those prices I could probably pick up some custom made in my size. I used to remember the name of a place that could/would do the bolt pattern, backspacing, andall of that for $1200. Maybe if I look around a bit I can find their info.
It's either that or I just grab some of those "OEM" ZR-1 wheels for $600.
But if it is cheaper for Ren?Vlietstra to get BMW replicas and have the specially fitted then have at it.
Jason
Old Sep 19, 2004 | 09:37 AM
I can have the set BMW replica's, tires included for around 1300$. If I have to order from the states even the simplist 18" polished IROC's, shipping and taxes included would cost me around 1200$, that's without the tires.
Old Sep 19, 2004 | 12:15 PM
joekickass's Avatar
Engine: 2.8
Transmission: auto
you guy are all lucky, especially the American, those after market rim for thirdgen will cost me much more than US1200 with tires, the good news is, those replica BMW rim are made in Taiwan, I got mine about US420 with used tires.....
If I am rich, I will still buy those US style rim, even the BMW rim look very too.
Old Sep 19, 2004 | 12:17 PM
I have been looking BMW rims on eBay, and I love the styles of most of them. I think my next set of rims will be from a BMW.
Old Oct 12, 2004 | 05:18 AM
MerF's Avatar
Car: '88 IROC convertible
Engine: Freakish 305 TPI
Transmission: Dying 700r4
Axle/Gears: LT1 rear
I love reading posts from people with English as their second language.
Lots of good info, thank you much to Rene and joekickass for the BMW info!!! I do believe I know what I will be looking for. now to find some cheap (but decent looking) knock-offs...yumm.
BADNBLK
Nov 16, 2016 09:12 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
