converting taillights
Car: 87' GTA
Transmission: 700r4 soon to be a t-56 6-speed
Hey everyone, just wondering if I should do a tail light swap from my T/A lights to a pair off a formula, kinda like the 5.0 guys do with GT stangs. I prefer the look of the Formula ones, but would like a second oppinion. I was also wondering how difacult it would be to change them. Thanks, Ben
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Re: converting taillights
Car: 1992 Firebird convertible
Engine: 3.1
they will interchange, but it will look like u have two lights out, some sort of small lights like a license plate light, mine werent used when i put '88 T/A tail lights on my formula...
Car: 87' GTA
Huh? What does them being used have to do with it, and why will they look like there out? You did the opposite of what I want to do, you put T/A lights into a Formula, I want to do the reverse.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
From what I have read, you have to do a little re-wiring down under the dash so that you can separate the turn signal from the brake light. May have to do some re-wiring at the rear harness as well.
I was looking into doing the re-wiring for my 91-92 GTA lights to go onto my 86 Trans Am, but I went ahead and put them on the Formula since the Formula is already wired for a separate turn signal.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
yeah, you're best off getting the light harness out of a base firebird, or a formula, since the harnesses are different. your current harness has four bulbs on each side (two brake/turn signal bulbs, one reverse light, and one bulb that just lights up red). the taillights you want to put in have six bulbs on each side (two brake lights, one reverse light, two bulbs that just light up red, and one turn signal). the swap isnt very hard, you unscrew your plastic interior panel in back, unscrew the plastic wingnuts, then pop out the taillights and bulbs. after this, if you have the harness you need, you unplug your existing one (which should be on the drivers side near the plastic wingnuts you unscrew), remove it, then install your new one. after this, you simply reverse the process above... I did the swap you're talking about, only i went from the red taillights to 85-90 t/a tails. I was 16 at the time, and i could figure it out.. so its not too difficult..
Car: 87' GTA
Hey guys, Thanks alot for the help, I know my way around a motor pretty good, but wiring is a whoal different story, so thanks for the tech help. I think the new lights should look good on my T/A, LX tailights always look better on GT 5.0's.
