Engine cleaning and detailing
Old Nov 10, 2004 | 11:46 PM
subliminal's Avatar
I have degreased my engine a few times using the Gunk Engine Bright stuff but it isnt getting my engine as clean as I would like. Even though there is no grease or dirt on my engine the TPI Plenum and runners still look dirty, Is their any cleaners and methods you guys could reccomend to clean my Engine bay. Thanks alot
Old Nov 11, 2004 | 02:27 AM
subliminal's Avatar
Anyone?
Old Nov 11, 2004 | 11:35 AM
A88GTANotchback's Avatar
on the runners just use sos pads...ull get a decent shine...no where as good as polishing them but still nice...onthe plenum....sand it all down and polish it.
Old Nov 11, 2004 | 06:13 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
sand and polish all of it including the runners. cleaners like engine brite dull them rite up. while your at it polish the altinator and ac parts, get some black spray paint for the brackets, and when your all done spray some clear on the black plastic and hoses ect and it will look new. its a used car resto trick to clear coat the engine to get that clean new shine look. and it does hold up pretty good if you keep it clean from there. rattle can clear is all you need.
oh and for cleaners i like the simple green, cuts grease and dirt real well and smells so nice too
jeff
Old Nov 11, 2004 | 06:49 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
You could polish it
Old Nov 11, 2004 | 07:00 PM
Big AL91's Avatar
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
:hail: 406TPI, looks Great!
Old Nov 11, 2004 | 07:49 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
By only adding degreaser your only removing the heavys for the most part, you need to actually scrubb off the crap. Most times you will need to do touchups, and even some hi temp clear coat from Duplicolour works great to keep it really nice... but polishing does look great too... here's mine...
This was my old system before, just painted.
Paint removed.
Polished
Vintageracer
Jan 10, 2020 05:33 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
