Scratches are makin me go nutz ??!?!
Old Nov 20, 2004 | 07:35 PM
nick418's Avatar
Engine: L98, Hemi 6.2
Hi guys, seems like on my hood and fenders and all over my car theres tons of small scratches from i guess dryin and washin my car.. Its really pissin me off, any good techniques you guys use to cure these scratches without screwing your paint more? ( yes i have BLACK color paint) I herd wizards makes good stuff.. I dunno, spit out what you guys think i should do LOL
Also i heard wet sandin is good to take scratches out, is this true? Thanks guys! I would really like opinions from guys who own black 3rd gen.. Thank you
Old Nov 20, 2004 | 07:52 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Are you talking about swirl marks or actual scratches?
Old Nov 20, 2004 | 08:03 PM
nick418's Avatar
i have no swirls.. There scratches. Lil small light scratches. It some areas like the fender, it looks like someone leaned agianst it and RUBBED on the paint..
Old Nov 20, 2004 | 08:25 PM
Daytona T/A's Avatar
Car: 1983 25th Anniversary Daytona 500 Pace Car Trans Am
Engine: 5.0L 305 Crossfire-Injected V8
Transmission: 4 spd. auto
yeah, I think we could all use some tips on removing scratches
Old Nov 20, 2004 | 10:59 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
buffer and compound, wet sand if they are deep. get a mild fine grit nothing to agressive. and you need a buffer too
Old Nov 20, 2004 | 11:03 PM
nick418's Avatar
there kinda like these, but not as deep as this, but this is what it kinda looks like but more lighter in a way
hey shawn sorry for usin your pic man
Old Nov 20, 2004 | 11:04 PM
nick418's Avatar
kinda what it looks like, but not as deep as this
Old Nov 20, 2004 | 11:27 PM
JeffW's Avatar
Engine: 305 tpi LB9
a buffer will remove that. it would be even quicker if wet sanded first with like 1500-2000g to take the edge off em. then it would buff even faster.
it really depends on how much and what type of paint you have. clear coats are easier to buff than single stage paints from what i have read. i have buffed a few clear coat paints and have had real good luck with removing all the little scratch off em. if the paint job is thin the buffing won;t help you can only sand and buff some many times before it is gone.
Jeff
Old Nov 21, 2004 | 12:08 PM
I've always wanted to try wetsanding but I'm too nervous... is it easy to screw up or can an average joe get awesome results?
Old Nov 21, 2004 | 01:08 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
that was a picture of my car that Nick Posted....that's what some wind and a tarp will do (long story). The whole car looked like that on all of the body lines...including the fenders, hood, spoiler...just about everything. I had to use a high speed buffer with some "Perfect It III" by 3M and several other compounds/polishes. We got them out....but they were very very deep. If you have scratches that deep..then nothing will work by hand...you will have to have it done with a high speed buffer. Since you dont know to much about this stuff Nick..I would get a pro to do it.
Old Nov 21, 2004 | 01:19 PM
JeffW's Avatar
Engine: 305 tpi LB9
it really depends on how muh paint is on the car. i painted mine with 3 heavy coats of hok clear so i knew i could go pretty far. but with a mild 1500-2000 grit wet sand paper it is pretty forgiving use a block to keep it smooth. not your fingers, you could sand a indent in the paint. and then you must have a high speed buffer to take the scratch out, i buff at like with my makita set at 3 which i think is around 1500 - 1700 rpm.
Old Nov 22, 2004 | 12:34 AM
Kandied91z's Avatar
assuming the mileage on the car the paint should be original.. pay a professional or practice on something other then your car.
Old Nov 22, 2004 | 08:14 PM
well my T/A hasn't got any real problem areas but it's just got the normal light scrathes and swirl marks when you look at it just right. Otherwise the paint is beautiful and I get lots of compliments. She's also white so the imperfections are less notable. Is this something worth taking 2000 grit to the whole car or should I just stick to polishing?
Old Nov 22, 2004 | 08:21 PM
Kandied91z's Avatar
perfect your technique.... if it's fine scratches then you just need to learn how to use the polish and make sure you dry your car with something better then you are now. sanding should only be used on new paint, single stage or as a last resort on older paint.
Old Nov 22, 2004 | 08:26 PM
I dry my car with micro-fiber or with a leaf blower but swirls, etc were there when I bought the car. I guess I'll have to keep working on the polishing this winter, then, 'cuz it's not working so far thanks for the info
Old Nov 26, 2004 | 06:41 AM
86SCBNJ's Avatar
Just some tips from a long time owner of red and black cars:
Use microfiber towels and applicator pads.
Clay the car before waxing or polishing to remove contaminants.
I have found when used with high quality products, these two hints have preserved the paint to a almost showroom quality.
Old Nov 26, 2004 | 10:23 AM
Engine: 5.7
applicator pads
microfiber applicator pads? I'd like to check some of those out..I've never seen any of those..
Old Nov 28, 2004 | 07:47 AM
86SCBNJ's Avatar
www.JnJAssociates.biz
morrow
Jan 13, 2024 12:29 PM
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
Eric-86sc
Feb 25, 2016 09:02 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Royal_Z
Sep 30, 2015 08:45 PM
