Routing spark plug wires so they look cool
Old Dec 10, 2004 | 01:11 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Not sure where to post this, but it does in a way fall under "appearance".
Does anyone have a pic of ways to route plug wires the best.
I dont want those cheap seperators either that just hang there.
I havent been able to find any seperators I;'ve seen at shows...but I'm looking for some heavy duty ones that attach somehow to the valve covers... Also I'm not sure how they would attach to the covers.
any help or pics would be greatly appreciated
Old Dec 10, 2004 | 01:16 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
try a search for "wire looms" if you're looking for the seperators. I found some sites for you that have some examples.
Hope this helps
mitch
http://www.jdrcustom.com/Zoops_Wire_Looms.html
http://www.performancechrome.com/en-us/dept_431.html
http://www.sallee-chevrolet.com/RandM/
Old Dec 10, 2004 | 01:25 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
I cant rember what it called but my dad has a reconfigured cap on his chevelle with an hei system ill ask him who its made by when he gets home this way you can jus use basic seperators and it looks very very clean
Old Dec 10, 2004 | 02:20 PM
25THRSS's Avatar
for centerbolt valve covers I prefer the made for you wire looms.
Old Dec 10, 2004 | 10:16 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Very important, make sure you get some for centerbolt valve covers. (Which is what you probably have on your '89). Otherwise the A.I.R tubes will be in the way.
I have a special problem, perimeter bolt heads with A.I.R. tubes. I have yet to fine a wire loom that will fit my car.
Old Dec 10, 2004 | 10:36 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I've got the Made For You ones, I like them. Sorry, but I don't have any good pics though.
Old Dec 11, 2004 | 12:32 AM
Abubaca's Avatar
I like the made for you looms, but I wanted something a little more visible...not so subtle.
They are Russells centerbolt looms.These come in red and blue anodized too.
Old Dec 11, 2004 | 12:41 AM
Kandied91z's Avatar
mine were wired underneath the headers and behind the block so they weren't seen.
Old Dec 11, 2004 | 12:52 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
Here's a the only pic I can find with mine.
Old Dec 11, 2004 | 01:35 AM
EvilCartman's Avatar
Car: '82 Z28
Kinda drooping in this pic but they're the Made for you vertical separators.
Old Dec 11, 2004 | 02:40 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
What kind of wires did you use? Same as the ones you had before that setup? Did you have to change the wires at all to do that? That's how I'd like to do mine. I hate seeing all the wires. I'm trying to get rid of as many as possible.
Old Dec 11, 2004 | 12:45 PM
CaysE's Avatar
The Russells are hands-down the hottest!
Old Dec 11, 2004 | 12:46 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
I'll get some pics of mine when I have time. It's dirty so don't laugh
Old Dec 11, 2004 | 01:07 PM
Kandied91z's Avatar
i did not have to change but i did change. i had magnacore.
Old Dec 11, 2004 | 09:54 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
How'd you hold them down there?
Old Dec 11, 2004 | 10:31 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
heres an old pic of my made for you looms:
Old Dec 11, 2004 | 10:33 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
meh, here it is
Attached Thumbnails Routing spark plug wires so they look cool-adscn3111.jpg
Old Dec 11, 2004 | 11:43 PM
Abubaca's Avatar
I think the Made for you looms are perfect for that 100% all business look. I like the Russels because they add a touch flair if you will. I know not everyone is after that look, but that was my logic.
FYI the Russell's were a pain in the **** to install. I have the 8.5 MSD wires and they were a little too thick. I had to hollow out the holes in the black holders. They do say "up to 8mm" so that's not their fault. The black holders were a pain to mount on the aluminum loom pieces too. I'll go into detail if anyone was interested.
...They're worth the effort for the look IMHO, but I was cursing Russell the day I put'em on.
Old Dec 11, 2004 | 11:47 PM
Abubaca's Avatar
Here's one more!
Attached Thumbnails Routing spark plug wires so they look cool-anotherloom.jpg
Old Dec 12, 2004 | 12:22 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Originally posted by Abubaca
Here's one more!
That is by far one of the cleanest engine bays I ever saw. That pic is beautiful....
Old Dec 12, 2004 | 01:37 AM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
I run mine under the header, so you can barely see them
Old Dec 14, 2004 | 05:42 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Do you have a part number for Magnecore wires that are long enough to run them that way.
Old Dec 14, 2004 | 06:13 PM
Car: 89 RS
Here's one more!
That setup looks exactly like the one I have. I can't remember the brand name but I bought it a loooooong time ago. I think Russell just took the design & made it their own. I do like how it has the cutouts in them though I'll post a pic of mine when I have time.
Old Dec 14, 2004 | 06:39 PM
Car: 89 RS
Here's the pic. Everything's dirty so don't laugh now!!!!!
Attached Thumbnails Routing spark plug wires so they look cool-tbi-wire-loom-pic1.jpg
Old Dec 14, 2004 | 06:41 PM
Car: 89 RS
one more closeup
Attached Thumbnails Routing spark plug wires so they look cool-wire-loom-pic4.jpg
Old Dec 14, 2004 | 06:57 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
acescarrsRS:
Is that a stock TBI, with ultimate mods? If it is, nice job!
Old Dec 14, 2004 | 07:01 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
oh wow, those look pretty cool.
wish my Throttle Valve Cable was as long as yours....
Brandon
Old Dec 14, 2004 | 07:26 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Werd!
Old Dec 15, 2004 | 06:32 AM
Car: 89 RS
Originally posted by nidyanazo
acescarrsRS:
Yup yup! Stock TBI. I used a hacksaw to get most of the top material off (don't laugh lol!) and finished it off (blend & radius everything) with a dremel. Then smoothed everything out with different grades of sandpaper
Thanks for the compliment!
Old Dec 15, 2004 | 06:34 AM
Car: 89 RS
Brandon
Good genetics! lol! nah nah! funny comment though
Old Dec 15, 2004 | 08:28 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
The Russel peices are nice but if you have to run air tubes, they suck. I took mine back cause the plug wires rode on the air tubes. Anybody else have "looms" for our cars with air and headers? Made for you are ok but looking for other options.
Old Dec 15, 2004 | 10:01 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
This is how mine are routed. The color is not my favorite but it was what I had available at the time. If im given a set of new taylor wires, im not going to throw em away because I don't like the color.. shiyet! (they were purple when I got the car!)
More pics in here
Old Dec 16, 2004 | 05:44 AM
TunedPort 335's Avatar
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Go under the headers...MSD wire looms here
Old Dec 12, 2020 | 06:50 PM
Ursula91's Avatar
Re: Routing spark plug wires so they look cool
Originally Posted by KagA152
meh, here it is
i would like clarification on what type of looms these are?? Name? Brand? Etc
Thank you
Old Dec 14, 2020 | 09:27 AM
Abubaca's Avatar
NECRO POST!!!!!!!!!!!!!! LOL, this thread is 16 years old.
HOWEVER....since info is info, regardless of age, those looms that KagA152 posted are "Made 4 You" brand looms. Smoothie looms specifically I believe. I had em for several years and they worked well and looked great. Might even still have 'em if you're interested in em.
Old Dec 15, 2020 | 10:44 AM
Ursula91's Avatar
Hey yeah if you still have them laying around I could be interested. How much do you want for them?
Old Dec 15, 2020 | 01:10 PM
Abubaca's Avatar
If I still have 'em, you can have 'em. ....lemme check tonight.
Old Dec 16, 2020 | 01:29 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Do not forget, adjacent wires should CROSS each other, a one point, to prevent "Crossfire".
Old Feb 3, 2024 | 12:19 PM
hassgrant's Avatar
Car: '91 Z28 305 TPI
Transmission: Manual
Old Feb 3, 2024 | 12:54 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Plug wires should cross at an approximate 90 degree angle, once, to prevent "crossfire". One cylinder inducing spark into another cylinder. keep that in mind as you make it pretty!
Old Feb 3, 2024 | 12:55 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I also really like the Made For You looms from Summit. I use them on my GTA that has headers and A.I.R. tubes. I don't have a picture of it handy, but I do of my convertible. It has manifolds and A.I.R. tubes. I went a slightly different route with it though. Most of the wires are routed against the firewall and down below the manifolds with the exception of the front two on the driver side. Those I routed on top with the MFY looms.
Old Mar 25, 2024 | 12:03 AM
  #42
Clean87TA's Avatar
Luckily for me routing plug wires isn’t so bad haha..
Old May 4, 2024 | 08:39 PM
  #43
ProZZac's Avatar
Car: 91 GTA
Engine: SP383
Transmission: Performabuilt 700R4
Old May 4, 2024 | 10:10 PM
  #44
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
spark plug wires...?!?... "I haven't heard that name in years" !
Just kidding!
With this engine, as well as the old TPI 305, I hated seeing the wires run on top of the valve cover, so I would always buy the "make your own plug wires" and cut them to length after running them under the headers and tucked out of sight. I like to use those billet wire/hose separators too.
Old May 5, 2024 | 11:26 AM
  #45
Originally Posted by ProZZac
Love those valve covers. Been looking for a set that will fit my '91 GTA for a long time.
Sparkytfl
Apr 24, 2009 09:44 PM
Stephen
Aftermarket Product Review
Oct 5, 2007 03:49 PM
icebird_1981
Feb 18, 2006 03:59 AM
Thirdgen86TA
Aug 6, 2003 09:55 AM
SpikeIROC
Dec 29, 2002 07:31 PM
