Painted 4th gen rear done..
Car: 1992 Jade Green---Trans Am Converti
Finally finished the my 4th gen rear. A lot of sanding and painting, but I think it turned out nice. Got new pads, rotors, hard lines, soft lines, emergency brake lines, and seals.
Calipers are painted with the brush on paint that's in all the parts stores now. Turned out nice, but the 2-3 coats turned into about 7 to get good coverage. I'm now that much closer to getting my new rims on, I've all ready got my 2" adapters for the front.
Now if I could just get the car back from the body shop..
Kevin D.
Before:
Kevin D.
Before:
Car: 86 Iroc-Z28
Engine: FB385
Nice job man! I need to do the same to my Moser rear before I put it in. $2000+ for the fu**ing thing and it is rusted in less than a day after receiving it and keeping it in my garage! What did you use to paint it? I am thinking of using POR-15.
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
brush on rustoleum in the gallon cans would work very well on a rearend.
On Probation
Car: 1986 Trans Am
okay, heres a n00b question for you guys, what is that red bar that is mounted about half what between the brakes and center of the rear? on the passenger side?
its not a sway bar is it?
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
yes thats the panhard bar it keeps the rear from moving side to side and plant squarly under launch and plant while cornering.
Originally posted by 18inchboyds
is that por ?Well whatever it is it looks much better than before.
The new hard lines made a huge difference.. Only like $28 shipped for the stainless from In-line Tube. They don't list the 93+ axels, but the one's for the 92 disc rear worked fine. I have no idea where the extra 2"'s on each side come from, but they worked..
Kevin D.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
It looks really good! I wish I had the $$$ to upgrade my brakes. Here's my rear axle just after coating it with POR-15. I've since added some black paint to the bolts and installed in on the T/A
Originally posted by Spdfrk1990
A aluminum cover would look nice on there.
Kevin D.
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
heres mine 9 bolt. I painted the cover silver/aluminum/whatever that can had in it that gave it that color. looks good in there now.
Originally posted by 86BluePearlIroc
Wow, good job, how long did that take you?
Kevin D.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
i think thats correct
