Spoiler Bolt holes on hatch...
Car: 85 TA
I want to swap the hatch from a firebird which has the wrap around spoiler on it to my Z28 which has the 3 piece. I know i dont have to mess with the 2 sides on the camaro however will the bolt holes be covered up when i take off the wrap around one and put the z28 back on the firebird hatch?
On Probation
Car: 1986 Trans Am
ok, i assume it wont cover the holes with a 3 peice spoiler...only because the holes for a wrap around are about half-way up the decklid...unless you mean the high rise? in which case the holes still wont match up (different locations)
not sure if this helps or if the pic is close enough, but heres my hatch after i took off the wrap around spoiler...
if the pic doesnt work go to my Firebird page, Page 2 at the bottom has the pics
Car: 1987 Trans Am
Not sure if it will work or not, but if not you could probably find an undrilled decklid from a thirdgen with no spoiler. I have welded the holes shut before to use a different spoiler, but the undrilled ones are pretty easy to find.
Car: 85 TA
j
Thanks all,
budweiserbeauty---------
In the middle, that the hole that closer to the rear window suposed to be there? Or was is rust all the way through?
Thanks,
Thanks,
Ok, dont take the wing off the hatch
you are doing what i did puting the wrap around on,just take the hole hatch!
with the wing and hatch it makes less work trying to mount the wing, so take the hole hatch off
the middle holes are for the third brake light.
im not sure about that highest hole, BadBlackFormula, but i will find out for ya.
and i only took my wing off to re-paint it but we found it easy to take off and put back on. the clips that it hooks onto, they were rusted out bad, so we just mickey moused it on there. im not too concerned, way i see it is, whatever works, it aint a showcar!
Re: j
Thanks,
Thanks,
Car: 85 TA
Re: Re: j
Originally posted by budweiserbeauty
the hole that is closer to the rear window is for the 3rd brake light wire. so yep, it is supposed to be there. to put the z28 spoiler on the firebird hatch, you'll prolly have to plug that hole. hope this helps!
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
C409
Sep 23, 2015 04:30 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
