pro-kit with 18s
Car: 1988 Camaro IROC-Z
pro-kit with 18s
I'm pretty set on going with the eibach pro kit but i wanna know what my iroc will look like with 18s and the pro kit springs, any pix? or are 17s the only lagitemat answer for the prokit..
In my opinion, bigger wheels and lower drops go together. I'm getting ready to install the Pro-Kit as well, and I'm keeping my 16" Irocs. With 18"s, my opinion would be to run sportlines.
...but that's based only on appearance, and again, it's just my "opinion".
well ur opinion counts for alot abubaca. i actualy feel exactly the same way, its just i see all these awesome 3rd gens with 18s now and i want it, if i only did a few things differently with my buildup so i could have them
i was hoping somebody could convice me with a pic that it would look ok.. still holding my breath hehe.. LT's are my enemy
Depending on what sidewall you run the overall diameter doesn't have to be much different than the factory wheels.... once you go to 19 or 20... then you really need to worry about stance.
Car: 1985 Iroc-Z
Transmission: t-5
I would say sportlines. The pro kit is not a very agressive drop its more for performance than looks. It would leave to much gap with a 18 w/low profile tires. It would kind of have that 4X4 look cars get. (refering to the overall height)
My personal opinion on the Pro-Kit and 18's, I think you'll have too much fendergap. The smaller the tire sidewall gets, the lower the car has to go to maintain the aspect ratio between the wheel and the car. Otherwise the ratio is off and it appears the car is sitting higher than it actually is.
I agree.. lower is better... but technically you can keep almost the same size diameter as stock... once you hit 19/20.. the diameter is bigger than stock so you really run into problems.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
here is pro kit with 17's if its any help, even if you go 18 you match the tire size to keep an original height of the tire. i have two diffrent size tires but they are still the same rolling size as the stock 15's.
sportlines are lower but i have also heard bottoming out problmes are more evident with the sport vs pro kit.
jeff
jeff
JeffW, that looks REALLY low for a Pro-Kit. Is that your car? If not, I'd say it has Sportlines (or similar) and not the pro-kit.
....and as far as going with 18's, I can't stress this enough. Do what you want, but don't dismiss staying with the 16" stockers. I regularly get compliments on mine. Without fail, everyone says that it's good to see a car without 17s or bigger. Big wheels do look good, but that doesn't meant 16's are bad. It's a different look, and it all depends on what you like.
Originally posted by IROCZTWENTYGR8
Keep the IROC-Z rims IMO.
Maybe i could at least go with some 17's and get away with alittle in the looks department
Or i'll just polish up my stock IROCs Supreme Member
Engine: 305 tpi LB9
yes my car and i did the install so the were pro kit for sure. sits mean doesn't it
jeff
jeff
Car: 91 RS
Engine: 350 TBI
jeff
jeff
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i havent seen many thirdgens at all with aftermarket rims let alone 18's.
i seen some 18 and 20 inch irocs before and one Z06 rim set.
also seen torque thrusts before
but nothing else for that matter
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Whats the widest tire you can put on a 16" IROC rim? Your gonna need some wider tires for sure with that beast of a motor.
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
im doin 20s with air ride.. only way to get it to lay as low as it is
the sportlines are the way to go if you are going a bigger rim..
just the way it is..
iroc2nv
iroc2nv
Car: 1991 Trans Am
Originally posted by SnkSknrZ28
Lookin like this is my only option.. I opted for crazy power when i built my car which forced me to go with LT headers, and now a true dual exhaust, so now i'm stuck with the stock look, not that it looks bad at all, i like it, just like all these cars with 18s alot too thats all lol..
decisions decisions..
Or i'll just polish up my stock IROCs Thread Starter
i do have ALOT of motor but when i need traction i can just slap on the 15 inch welds with some hoosier qtps and be ready to go
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Originally posted by 91NiteRida'
Here is my camaro...18s with the sportline kit
EDIT:The pics were taken a week after I installed the drop...It sits 1/2" lower now that the springs have settled
Car: 1988 IROC-Z
Engine: 427 SBC
it'd be cool to roll on some 17s.. how bout the ronal firehawks, how would they look on my car u think?? they are simple, cheap, nice deep dish which i like.. any comments..
I think it would look awesome
Originally posted by JDubya18
ohh thats sick. How much ground clearance do you have at the sideskirts there? I was thinking that I wanna go with 18"s and Sportlines but I dont wanna end up bottoming out all the time.hows the ride too?
...As for the ride,its not horrible and its not a caddy.It really depends on the shocks and strut you go with...Im running my stock 120K mile shock/struts and I dont lose my teeth while i drive
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I didn't think the eibachs had to settle. Mine is still the same ride height since the day they were installed. If I had the chance to get a different wheel...I would have went with 18's myself.
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
gonna have pics of my new 18's and prokit springs later this week...running them on brand new bilsteins all around (spent too much money on the car to put it on airride...gonna wait til next year)
.....plus Im shopping for an engine, Im still dealing with that wimpy 305
.....plus Im shopping for an engine, Im still dealing with that wimpy 305 Thread
CrazyHawaiian
Aug 28, 2002 10:46 PM
