Custom washer tank????
Old May 4, 2005 | 01:53 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
Has anyone made a custom washer tank? I was thinking about making a round aluminum tank that would look like a catch tank. Something like the BeCool design. Has anyone here done this? Any ideas where to mount it? I would think the only good place would be right at the side of the radiator. I figured put the pick up on the bottom and a cap of some sort on top.
Old May 4, 2005 | 07:56 PM
Megaracerx2's Avatar
On Probation
Car: 1986 Trans Am
sounds like a cool idea, maybe make it out of a clear plastic, that looks like glass?
i say keep the stock mounting location.
Old May 4, 2005 | 09:01 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
You could use a washer tank/pump from another car too. I've got a small one from the rear of an RX7 that I attempted to turn into an anti tailgating device.
I like the chrome catch can idea. But a pump will still need to be hidden. The first spot to hide it that comes to mind is in front of the radiator underneath the plastic trim that surounds the hood latch. Or be lazy and use the 4th gen tank/pump. It fits in the stock location IIRC and is much smaller.
Old May 4, 2005 | 09:59 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
I'm still going to use the stock wiper motor that has the internal pump. So I guess that I only need a tank that I can suck from that will let in a little air as it empties and has a way to fill. I think I'm going to make a round aluminum tank with the becool screw on cap on the right side of the picture and a hose nipple on the bottom.
Old May 5, 2005 | 04:12 AM
Sinister Z's Avatar
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
ooops!
Old May 5, 2005 | 04:13 AM
Sinister Z's Avatar
Originally posted by The Sinister
I have the a Custom Washer and Antifreeze Overflow Tanks in my car, This is an old pic of the Antifreeze Overflow Tank mounted right beside the Radiator, the washer is exactly the same...I'll get a better pic for you later to give you an idea, the Tanks were made by Universal Spinners. Cost: $75.00 cdn each.
Old May 5, 2005 | 07:20 AM
MNformula350's Avatar
I used a ford exploder one myself, it is a combination unit with both washerfluid and overflow about the size of a battery. It's mounted on the driver side.
crappy close up pic: i should really take one with my digital camera
Old May 5, 2005 | 09:20 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What is the size of the overflow tank you are using?
Old May 5, 2005 | 09:23 AM
Sinister Z's Avatar
I'm not sure exactly...good question!
Old May 5, 2005 | 04:10 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
From what I have seen most of those aluminum overflow bottles only hold a quart. In a Phoenix summer that just ain't gonna get 'er done. To bad I like them though. But I might give it a try.
Ofcourse I'll probably have to do black chrome!!
Old May 5, 2005 | 06:14 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Dave84Bird - THATS AWSOME engine bay looks so much cleaner
Old May 5, 2005 | 06:45 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
look in the upper right corner oops forgot pic see below...
Old May 5, 2005 | 06:48 PM
BumpaD82's Avatar
ok here it is
Old May 5, 2005 | 06:49 PM
Car: 1987 Z28
Is that gatorade
Old May 6, 2005 | 07:45 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I have a small one from an 85 RX-7 mounted down low on my fenderwell, looks MUCH cleaner!
Old May 6, 2005 | 11:08 PM
On Probation
Car: 1986 Trans Am
Originally posted by 83_Camaro_83
Is that gatorade
no. its clearly Orange Juice.
Old May 6, 2005 | 11:12 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
Personally i like the look of the stockers as long as they're nice and new
Bohemian
Aug 15, 2017 05:11 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
