fogged up parking lights
Old Jan 5, 2001 | 12:17 PM
KS91Z28's Avatar
I want to replace my old, dull, fogged up parking lights up in the front bumper. Is there any way to keep the new ones from fogging up? Could I just spray a clearcoat on them? Would that keep them from fogging up?
Old Jan 5, 2001 | 05:42 PM
Fastcamaro87's Avatar
i think that the fog is on the inside, probably from moisture, classic industries has new ones or if i were u i would get some meguiars clear plastic polishing compound, rub the hell out of them, then dry out the inside real good, and check for leaks or cracks in them and seal them with clear silicone, its amazing how good an old part can look with a little TLC.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Jan 5, 2001 | 06:07 PM
DaBandit's Avatar
He is right, there just might be some "fog" inside the actual lens. This happens when there is a bad seal.
Old Jan 5, 2001 | 06:24 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's always a 'bad seal'. They have a vent that allows all of the moisture to get in there. If you plug the vent you may have overheating issues with the bulbs.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 5, 2001 | 11:00 PM
Drew's Avatar
This comes up quite a bit... You could have one of two problems... either the lense has condensation inside, or the lens has been beaten by bugs, weather, uv rays etc till the plastic is hazy... Either way the fixes are the same. Pull the lense, they're held in with two 10mm bolts from the back side. Clean the lense inside and out with soap and water. Dry the lense however you can, I used an aircompressor. With the lense dry check it out, if its fine, make sure the drain holes are clear and reinstall. If not break out the plastic polish. I used vary rubbing compounds and polishes with mixed results. I'm convinced the polish didn't matter as much as the repetition... When the surface is smooth follow up with a coat of Zaino plastic polish if you want a nice shine. If it still isn't good enough, save a few bucks and talk to a GM dealer. Replacements are cheap.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6
92 S10
98 Grand Am GT
Old Jan 5, 2001 | 11:31 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Drew has some excellent ideas. Or you can modify them as I have:
<IMG SRC = "http://albums.photopoint.com/j/View?u=1427158&a=10788180&p=37204592&Sequence=0&res=high">
Almost three years with these and they're still clear as they were on day one.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Jan 6, 2001 | 06:57 AM
gregz28's Avatar
Wouldnt the problem recure if the vent is not sealed? And if it is sealed would it cause heating problems? I have taken mine out several times and dried them out, but the moisture wont stay away. I think Ill try sealing one or both and see what happens. The bulbs are less than $2.
91 Z28 305 tpi
plans for 383 or 502
flowmaster cat-back
Ram air to K&N cone
Old Jan 6, 2001 | 08:42 AM
Drew's Avatar
Try cleaning them... mine haven't gotten condensed since I cleaned them.
Drew
My Website
87 Iroc
91 RS Convertible
91 Firebird V6
92 S10
98 Grand Am GT
Old Jan 6, 2001 | 12:09 PM
TexasLT1's Avatar
Car: '92 RS
Willie, how did you get clear ones? that looks sweet. did you sand down the stock ones or make completely new ones?
Old Jan 6, 2001 | 09:39 PM
Josh 91RS's Avatar
Texas, go to ******* site...he shows how he made them on his site. Looks great on your car willie...not sure if those clears, or just some blacked out foglights will look better on my car...still deciding.
Old Jan 7, 2001 | 03:27 PM
KS91Z28's Avatar
I think mine are hazed from bugs and sand hitting them, and probably most of all the sun. I like Willie's idea. If I were to buy a brand new set, does anybody know a way to keep them looking clear?
Old Jan 8, 2001 | 12:12 AM
Drew's Avatar
yeah, its easy, garage the car and don't drive it... Or replace the lenses every 10 years. Hitting em with a plastic polish everytime you detail the car can't hurt.
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
