Quick question About rims
Old Aug 10, 2005 | 09:22 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
im more of an engine person than body and wheels....i plan on getting some either 17 or 18 inch havent decided yet...maybe you guys can help me decide which size....but im pretty sure im settled on the new C6 rims.....to my understanding i just have to buy the adapters to get them to bolt up...and would any rim place carry those or do i need to get them online...any insight from you guys would be great...and lemme know if u think 17 or 18 inch would look better...as u can see from the sig its a 92 RS red with blk stripes...just wondering cuz im seeing alot of packages being sold as 18's up front and 19's on the rear...do u think the 19's in the rear would be to much...thanks guys
Old Aug 10, 2005 | 09:44 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
Don't get 19"s in the rear. Your best bet is probably 17's. Anything bigger will be too rough of a ride do to the thinner tires that will go on. Not to mention that if you hit a big bump it could bend the rim since there isn't much tire to cushion it.
Old Aug 10, 2005 | 11:24 AM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
17 but if u can afford it 18 r nice
Old Aug 10, 2005 | 02:49 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
the reason you are seeing 18 and 19 combos is becasue that is the stock size. It also depends on what you want to car to do. I wouldn't plan on doing a lot of drag racing with 18s. I do like the look of 18s but 17s are much more practical for me.
Old Aug 10, 2005 | 06:43 PM
DanTheMan_smlk's Avatar
19's.......SUV wheels
Old Aug 10, 2005 | 06:50 PM
Stevo's Avatar
Car: Pair of 92 Z28s
id go with 17s...best all around look...can be good on the curves and drag strip.
not as expensive
dont weight as much
not as harsh as a ride
lots of reasons why there better thens 18s...only looks is the reason to go to 18s
Old Aug 12, 2005 | 08:56 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
what do u guys think bout 2 different size rims...cuz i can get c6 rims for bout 600 with 17's up front and 18's in the back or does it make our cars look weird....u think itll be best to stay with one size all around...and also is there anywhere else to get the adapters to make them mount up...just tryin to get some feed back soo im not dissapointed when i get them lol
Old Aug 12, 2005 | 09:36 AM
Firebat's Avatar
go with the same size of rim all the way around. Yes, it will look stupid otherwise.
I've heard 18s suck. They cause wheel hop badly.
Hawks third gen has 2" spacers. http://www.hawksthirdgenparts.com/in...l?v=1&pid=8921
Also check out ebay.
Make sure you get a least a 17x9 for the rear. Dont get anything less than 9" wide.
If it were me, i'd go with 17x9's or 17x9.5 all around. I'd go with the same tire all around too for rotating the tires. I'd go with 285/40/zr17 to have the tire 26" tall.
Old Aug 12, 2005 | 09:43 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
<p>Thats a good point. If you get bigger rims in the back then you won't be able to rotate your tires.
Old Aug 12, 2005 | 10:09 AM
Firebat's Avatar
Make sure you get chrome rims and not polished aluminum. Chrome is good...
Old Aug 12, 2005 | 11:18 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
lookin like im gonna have to go 18's the 17's are only 17x8.5...and the 18's are 18x10.5.....so looks like chrome 18s it is...not too worried bout the racing part its been a couple years since ive had it to the track...more of a street car and i guess i can deal with a lil rough ride
Old Aug 12, 2005 | 11:19 AM
Firebat's Avatar
what rims on the fronts? i dont think 18x10.5 will work up front
Old Aug 12, 2005 | 11:57 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I think the 17f/18r combo looks pretty good on thirdgens. As long as you don't care about the weight of your wheels you really can't go wrong when you start looking at 17s and 18s.
Old Aug 12, 2005 | 03:05 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hi
Get the 18s. They just squeek in there if they in just right. Anything bigger is going to rub your wheel well when you go around a corner. You could also just play it safe with 17s.
Speedmachine
Old Aug 12, 2005 | 03:49 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
here is an 18/17 combo, rears are 275/40/18, fronts are 245/45/17 and no rubbing in the front at all,
and an 18/18 combo, rears are 295/35/18, fronts are 275/35/18 and they rub a bit,
and a 17/17 combo, rears are 275/40/17, fronts are 275/40/17 and these rub as well
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
