What's bad about waxing your car alot?
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I don't know exactly why, but I remember reading that waxing your car to much is a bad thing. I don't know why, but I'd like to. I know of two people who wax their car a few times a week. Besides having no life, what are the disadvantages of it?
Car: '02 Z06
Maybe he accidently posted it in the wrong forum.
You wont necessarily hurt the car by waxing it alot, its just that you're not getting any more benefit waxing it 10 times over waxing it once. Wax will protect your paint for months at a time and the idea of doing it once or twice a week is just silly.
Car: 87 Formula
Engine: 327
You'll build up layers of wax & any dirt that you dont get washed off. Wax isnt perfectly clear either so if you build up a thick layer it'll actually change the color of the paint. You may not notice it cause it'll happen slowly. A friend of mine had a lifted show only white blazer. He used to use Liquid Glass on it before every show. Well after a couple years of this he noticed that the while the outside kind of was a cream color the jams were still bright white like they came from the factory. The wax (LG is technically not a wax) had yellowed the paint. He ended up having to use a solvent and very fine steel wool to get back down to the original paint.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you use an abrasive "cleaner wax", eventually you'll wear your paint off.
Otherwise, no problem. With normal waxes, when you apply them, you actually remove what's there, so you don't typically get a buildup.
However, if you like to wax your car a lot, buy Zaino. That polish actually is designed to build on itself, and the more that goes on, the better your car looks. If you keep the car clean, you won't get a build-up of crud between layers of wax, but as a precaution you could always clay-bar it on occasion to ensure that your paint is clean.
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Also, for the starter of this topic, check out this thread...
https://www.thirdgen.org/techbb2/sho...r+car+too+much
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Originally posted by a mack6
And if i were to use zaino, would i put a layer of wax on first??
Before using Zaino you need to wash with dish soap to remove all the wax first.
Zaino is a polish not a wax, you want a clean surface to start with.
Wash with dish soap (twice)
clay bar
then Zaino
a wax scatters the reflected light, Zaino magnifies it
Zaino also builds on itself, more coats= more shine
http://www.zainostore.com/Merchant2/...de=APPLICATION
But the question i am wondering is, can zaino protect a cars finish just as much as wax can???
Car: 1992 Camaro RS
Axle/Gears: Stock
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Re: What's bad about waxing your car alot?
i use meguiars gold class. after 2-3 coats of that stuff the car is covered in glass! i notice a difference in multiple coats, it makes it look deeper and more glossy. after 3 coats though its probably a little overkill....
maybe this isnt true but i enjoy waxing my car so i dont really care!
if your clearcoat is faded, cant waxing be bad? you will see the color of the paint on the cloth you are using. there is a small corner of my hood blister that the clear is fading on. every time i wax that spot i see red on the cloth. so i always avoid that spot. im prety sure it happens with regular wax, not just cleaner wax. i havent waxed mine since before winter so i cant really remember
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
