Zaino car polish
Old Jan 23, 2001 | 11:32 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
Zaino car polish
Has anyone used this stuff? Is it better than regular wax? I love the way my black car shines after a wax job but as soon as I wash it the swirls come right back, I mean right back, does this eliminate that?
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam.
Old Jan 24, 2001 | 04:40 AM
Jza's Avatar
Jza
I just got done putting the second coat of Zaino on my car (and yes, you're reading the post right, it's 4:33 in the morning here).
The shine is hard to describe. It's crisper, or clearer than the Meguire's 3-step I used before. But what's got me hooked is how easy it goes on and off (and the pleasant smell is a plus too..hehe) And the feel of the paint is unbelievable. Smoother and silkier than anything I've ever put on the car.
Oh god I'm starting to sound like the rest of the Zaino parrots...
Old Jan 24, 2001 | 07:12 AM
Chuck Everly's Avatar
Yes it is all it is claimed to be.
I see Jza is now hooked, next he will be begging his neighbors to wax their cars.
Chuck
Chief Zaino Parrot
"Somebody get me a cracker!"
EDIT: JDMZ28, It will help reduce swirl marks but if they are too deep there is not much that will help you short of a professional buffing.
88 IROC convertible
-=ICON Motorsports=-
[This message has been edited by Chuck Everly (edited January 24, 2001).]
Old Jan 24, 2001 | 01:10 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Yes it is great. You wont be dissapionted...
Kevin
Old Jan 24, 2001 | 01:24 PM
jm91rs's Avatar
Ok, where can I get it?
Old Jan 24, 2001 | 01:31 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I sent an email to Zaino Sunday requesting some help and I got the crappiest reply. I explained that I used 3M Perfect-It II Rubbing compound on the entire car, then used Meguire's Profesional Glaze and Swirl Remover, and topped it off with Turtle Wax Emerald Series liquid wax.
I asked them if I still needed the clay bar, and do I need to remove the above mentioned products from the paint before applying their stuff or could I just start using their products on top of what I have. The reply I got was a copy and paste of the procedures on their web site. So much for personalized customer service. If anybody here can answer my ??'s, I'd appreciate it.
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
Old Jan 24, 2001 | 01:50 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
How do you consider that a crappy reply? It staes to first strip your car of all the old crap you've been using and start with a frsh surface. Putting Zaino ontop of the Turtle Wax and Mcguires is not going to give you good results. Using dish washing detergent to strip the car of the old waxes first.
Old Jan 24, 2001 | 02:28 PM
Mo's Avatar
Mo
I would wash it first with dawn or whatever, but i was very unhappy with the claybar, didn't do a damn thing to my car except sound like it was scratching it, waste of 17 dollars. However the rest of the products I used were great...swirl remover, polish, etc
Mo
Old Jan 24, 2001 | 02:43 PM
jm91rs's Avatar
What is the website?
Old Jan 24, 2001 | 02:49 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
www.zainobros.com
Old Jan 24, 2001 | 04:24 PM
scottmoyer's Avatar
It was crappy because I did tell them that I read their website, but needed more info. After using rubbing compound on the car, I am assuming that all contaminants were removed. Also, I need to know if their swirl remover is needed or will the meguire's do the same job. As for the top coat, I am willing to get it but I don't want to buy their swirl remover if the contents and results are the same as Meguire's. It's the top coat that gives the deep shine, right?
Old Jan 24, 2001 | 04:48 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
The swirl marks in my paint are not deep they are only from dirt or maybe the wash mit I use. I have been able to remove them in the past with Meguire's but as soon as I wash the car the swirls and cloudy paint come right back. Will this eliminate that problem? Thanks
Old Jan 24, 2001 | 06:25 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Dude, it's a whole system of products that are designed and formulated to work only with the other Zaino products. You cannot mix and match them, it will not work. Different chemicals, different ballgame completely.
And if you're using the swirl remover do not expect an overnite vanishing of your swirls, it took time to put them in the paint, and it's going to be a work in progress to fill them in. But after a couple of layers, you'll see drastic improvement.
This stuff worked miracles on my TA before I got it painted, and if it wasn't for a little accident, I probably would have been happy with the car the way it was. Black is absolutly spectacular, when the directions are followed. If you want the best shine possible don't take shortcuts, do what Sal says. Too many people have tried all have come back saying they were idiots for not doing it right.
Old Jan 25, 2001 | 12:49 AM
Jza's Avatar
Jza
Chuck: the lady I ordered it from at GlossBoss knew of you by name when I mentioned the ThirdGen.org website. I said yeah, it was you who I got the link from..
And yes, I am hooked.
Old Jan 25, 2001 | 02:17 AM
Jza's Avatar
Jza
(Third coat going on now. I have a beer buzz; I hope it turns out okay)
lol
Old Jan 25, 2001 | 06:48 AM
I am famous didn't you know that?
Once you get the first coat on it is hard to mess it up so the beer buzz can only help
88 IROC convertible
9192camaro
16
Feb 3, 2019 12:21 AM
kah992
Aug 19, 2015 02:55 PM
kyleb24
Aug 15, 2015 08:24 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 5, 2015 11:57 PM
