Anybody ever put chrome valve covers on?
Old Jan 5, 2001 | 12:59 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
I am about to install some chrome valve covers on my 1992 305 TBI. However, I noticed that the passenger-side cover is buried under several hoses...I guess they're for the heater, emissions, or something. Anybody had any luck re-routing these hoses to clean up the engine compartment a little? Any pointers on installation of the covers will be appreciated, too. Check out my web page for pics of the engine compartment and you'll see what I'm talking about.
1992 Camaro RS
305 TBI, 5-Speed
K&N open element, Hooker exhaust
http://www13.brinkster.com/scbaeb/camaro.html
scbaeb@hotmail.com
Old Jan 5, 2001 | 01:16 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Sure, just get rid o fall that stuff. Then take your smog pump out and check the tech section for belt routing. That will elimintate alot ofyour hoses. you can shorten the heater hoses that go to the heatercontrol valve and extend theone from the rad and push them back further in the engine comartment. Pretty much aslnog as everything is routed the same you can do whatever you want. Heck you could drive the smog pump with a 5th whell you attach to your bumper as long as everything is routed the same. just have fun with it. and be creative.
Later,
Lars
BTW: Spend the extra money on good valve covers. Don't get cheap thin stuff it will leak. and don't go torque'n the bolts as tightas you can get them.
Old Jan 5, 2001 | 03:17 PM
84TransAm's Avatar
lars92rs is completely right. In addition to what he said, it might be worth your while to sand the area of the valve cover that is contacting the cylinder head so oil has absolutely no chance of slipping by. Most people who complain of leaks with chrome covers fail to do this (i did too). Driver's side should be a piece of cake though.....
--Steve S-- 84 Trans Am 305 (cough)LG4(cough), 5 speed, Flowmaster 80 series, otherwise an emissions restricted slow 150 hp(chilton rating) 240 torquer that needs RELEASE!!!!
P.S. Daily Driver
Old Jan 5, 2001 | 03:58 PM
DaBandit's Avatar
And plan on polishin' the 'ol valve covers pretty often if you drive down any dirty roads. Because on my T/A 6.6, they get dirty!
Chris "$teve" Williams
1984 Firebird "Stroker GT
2 1978 WS6 Trans AMs (one of which is a "T/A 6.6" 220 hp.)
http://www.geocities.com/butterscotch_kandy
[This message has been edited by DaBandit (edited January 05, 2001).]
Old Jan 5, 2001 | 09:36 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I can tell you from my expierence, it was a pain in the *** . I changed mine at the same time I redid my intake gasket. I had to pull them out from the sides towards the runners. I couldnt get them off going straight up. I guess if you take all the hoses off you can get to them. Maybe others could do it but I sure couldnt. Anyway I glad with the final results. I got the center bolt valve covers from the Chevy dealer. You can also get them thru Classic Industries and places like that. They are high dollar though. $139.00 for me.
microtech8@triad.rr.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Ported/Polished Plenum by "Daniel Burk"
Holley AFPR
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
My Car:[url]http://albums.photopoint.com/j/ViewPhoto?u=1426474&a=10682240&p=36621420[url]
[This message has been edited by Wishmaster's87IROC (edited January 05, 2001).]
1987 White IROC-Z
700-R4 auto tranny
97,000 miles
KYB's
Flowmaster Muffler
Holley AFPR
TPIS air Foil
K&N's
Gutted air box
Moroso Super Coil
Boush Patinum +4's
Old Jan 9, 2001 | 12:31 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Lars, I have attached an edited photo of my engine just to make sure that we are talking about the same stuff. Would you take a look at this and make sure I understood you correctly? I'd really appreciate it. Any other tips from anyone else on cleaning up the engine compartment will be appreciated, too.
1992 Camaro RS
305 TBI, 5-Speed
scbaeb@hotmail.com
Old Jan 24, 2001 | 01:42 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Witchmaster's87 Iroc-
How did you get the plastic peice that connects to your intake to look chrome(the peice that covers your distributer).
Or did you buy a chrome one...
1988 GTA (29,000 original miles):
Crane Cam, K&N
Flowmaster, Off Road Pipe.
Old Jan 24, 2001 | 01:48 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Crane Cam, K&N
Old Jan 24, 2001 | 03:02 PM
84TransAm's Avatar
I did this a week ago, and listed a "How to" there but i can't find it. Most of the steps are removing hoses, you have to drain the coolant and detach the heater hose. I had to remove the alternator, because an emissions accessory was in the way. Doesn't really take too long (if u have the right tools ). The emissions vacuum wires may be brittle and will snap like dry spaghetti, but u can replace them with rubber vacuum hose.
Once all the stuff is out of the way, it is very easy. I love the chrome valve covers, and feel that the push-in breather is a major improvement over the stock breather. (carbureted). Next thing to do is get a chrome air cleaner.
I only did this because i got a sweet deal on the valve covers. GM Goodwrench performance product from Jeg's is about $45, i got them for $16, new.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
RPO codes point to Recaro version
Daily Driver, Flowmaster 80 Series
[This message has been edited by 84TransAm (edited January 24, 2001).]
Old Jan 24, 2001 | 05:37 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
GTAlover,, I think that piece is from a vette,, if I remember correct,, someone said they were aluminum instead of plastic.
I'm sure Wishmaster could tell you for sure tho
My Firebird
Part Breakdown Diagrams
Old Jan 24, 2001 | 06:11 PM
yeah, I ordered it from the GM dealer, its off a 87 vette, the part# is 10108425
but it doesnt come polished you have to do that yourself....
Old Jan 25, 2001 | 04:46 AM
Jza's Avatar
Jza
Regarding that piece: Corvette ones are aluminum, Camaro/Firebird ones are plastic. You can get a 'Vette one and polish it like that.
Old Jan 25, 2001 | 11:24 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Please do not post ".bmp" files. They take too long to download for most people. Convert them to ".jpg" then they are fine.
Thank you.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
