How do i make my T-Tops look better?? Someone has to know!!
Old Sep 25, 2005 | 08:18 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Ive posted this before without any good responds...But my t-tops look like crap and i cant deal with it to much longer, how do you clean them up and how can you restore them?? Thanks
Old Sep 25, 2005 | 08:26 PM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
Which part of them looks like crap? The outside edges?
Old Sep 25, 2005 | 08:37 PM
Gr89RS's Avatar
Car: '02 Z06
If you have the lexan style tops, the "glass" can be buffed out to remove scratches. If you are talking about the trim, you can do like I did with my last car and sand them down and spray a few coats of black paint on them.
Old Sep 25, 2005 | 08:56 PM
BT283's Avatar
I am going to do the trim, but what kind of paint do i need...and i dont know what my t-tops are made of, they are on a 91 Camaro, i think it the lexan. What do i buff them with?? Thanks a lot
Old Sep 25, 2005 | 10:07 PM
CaysE's Avatar
Lexan is plastic. Otherwise they're glass. It should be easy to tell. I used a gloss black car paint from AutoZone to spray the t-tops, mostly because my car is already black and it matched up well. Normally you should use a satin finish black.
Old Sep 26, 2005 | 07:26 AM
BT283's Avatar
i have lexan then, i will do that, now how do you clean the center
Old Sep 26, 2005 | 07:07 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
well i used some plastic glass filler stuff that's made to fill in plexglass and plastics and such. It definetly works well but, requires a lot of elbow greese. It gets out all the surface stuff but, the big stuff still shows.
My dad told me about being able to sand it down or such with a real fine sand paper then buff it out or such. He said he saw about it on the d.i.y. channel but, we can't seem to find it on the site and i'd love to know because, mine are still to scratched up for my liking. anyways i hope someone has an answer to this!
Old Sep 26, 2005 | 08:09 PM
BT283's Avatar
me too! but using plastic polishing compound will really work??
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
