Paint runs
Old Sep 26, 2005 | 10:09 AM
iroc_cragg's Avatar
Paint runs
just got the car repainted and there are a few runs, how can I get the runs out without screwing up the paint. any suggestions
Old Sep 26, 2005 | 12:38 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
wetsand
Old Sep 26, 2005 | 02:05 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Are the runs in the clear or the paint? In the clear you can wetsand like camaroguy said. If the basecoat has run you can't.
Old Sep 26, 2005 | 04:29 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i have a really good solution for runs but most people are not confident(sp) enough to try it. take a fresh clean razor blade and wrap masking take onces around the edges. the tape will prevent the edges of the razor from scratching you paint. you have to hold it staight on the paint do not tilt it. then drag the razor along the run(don not apply presure). this will remove the built up clean in the run and not the clear around it. when your done,wetsand it with 1500 or 2000 grit paper and buff it. i have tried to teach this to alot of people but no one ever wants to put a razor to a new paint job.
my personal opinion is that there is no way to fix a run other than blocking it out and respraying it. if you wetsand and buff the run you will still see it, because you are sanding the run and the clear around it. so basically you will still see the run very noticably. the razor trick is the best method that i have used. it leaves a slight shadow that most people will never see. go luck and do what you feel more comfortable with.
Old Sep 26, 2005 | 05:06 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
the razor thing has actually been made and marketed in order to get rid of runs. eastwood actually has one for sale.. and they do indeed work for cutting the run down
http://www.eastwood.com/shopping/pro...=1&keyword=Run
Basically there is the "Run Razor and Block set" Works pretty decently.. (I have one and have used it to cut down the runs in a clear coat after i was done painting. (I do custom Computer case painting on the side, somedays are worse than others for doing that)
Old Sep 26, 2005 | 05:43 PM
iroc_cragg's Avatar
the runs are in the actual paint, its just a one stage paint, no clear coat.
Old Sep 26, 2005 | 05:55 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I'll be the next to agree on the razor. Take one to it, just be a little careful how you handle it, dont go at it carelessly.
Old Sep 26, 2005 | 06:32 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
You got it painted again?
Old Sep 26, 2005 | 06:53 PM
iroc_cragg's Avatar
nope talkin about my other car, the new IROC, its an iroc daytona haha,
Old Sep 26, 2005 | 07:03 PM
Car: 1987 Z28
ohhh your winter beater
Old Sep 26, 2005 | 07:27 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i used the razor blade method before too and it worked great. i didnt even wetsand it afterwards, just buffed it becuase it came out smooth as it was. im not sure about single stage though. anyways, i used this little block that looked like a stamp that my teacher gave me also, and it had like diagonal sharp edges. hard to explain but it also worked well. i would go for it if i were you, anything looks better than a run
Old Sep 27, 2005 | 04:24 AM
Note the link i put up about 3 posts from eastwod.. that would be what you used...(the little block) If you do a bit of painting it is a pretty good investment considering it is so cheap
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Catcher55
Aug 15, 2015 07:08 PM
