afternarket headlights
Old Dec 13, 2005 | 03:00 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
does anyone have these on with a different bulb they are the
82~92 Chevy Camaro CRYSTAL Headlights off of ebay. any pictures ill like to see how they look.
http://cgi.ebay.com/ebaymotors/82-92-Chevy-Camaro-CRYSTAL-Headlights-w-Adapter-IROC_W0QQitemZ8022563038QQcategoryZ33710QQrdZ1QQcmdZViewItem
thanks
Old Dec 14, 2005 | 09:26 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
dude those are otto headlights go to procarparts.com
these are the same headlights way cheaper.
Type in UN46IN-1077CH1 as the sku. and buy
now go to Summit.com and type in headlight.
click on the APC Headlight Conversion Wiring Harness Kits and buy .
Now you have a relayed high volltage kick %^& headlight that will not fry your system for just a little more and total quality you do not have to worry about
Old Dec 14, 2005 | 09:28 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
am I the only one for whom that link goes to microsoft.com ?
Old Dec 14, 2005 | 09:34 PM
jamon8's Avatar
Engine: 350 tpi
if you are talking about the one on the top it goes nowhere for me but I knew what he was talking about
Old Dec 17, 2005 | 10:41 AM
Lazer's Avatar
Car: 1989 Iroc-Z / 1985 Camaro
Engine: 5.7L 350 / 2.8L V6
http://www.procarparts.com/store-det...=onlinestoreDB
Do these sets work for high-beams too? Or will I just need to buy new bulbs?
Old Dec 17, 2005 | 12:52 PM
jamon8's Avatar
Engine: 350 tpi
if you look on the side it says 90/100 watts. If you get the wiring harness you will not have to worry about It.
Old Dec 17, 2005 | 01:08 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
As I am looking to do the same thing, I just want to be very clear as I will buy this weekend.
Go to
Procarparts.com and buy the new headlights.
Now the question here is do I buy 2 or 4?
Now I assume I purchase (4) as they go with the next purchase...
Go to summitracing.com and purchase the conversion kit
http://store.summitracing.com/partde...5&autoview=sku
This is the kit for 4, so I assume that my high beams and low beams will all work the same?
So basically 2 or 4? If 4 will high beams work? Will buy and even take pics of installation for everyone just need the right information upfront. Thanks
James
Old Dec 17, 2005 | 02:15 PM
jamon8's Avatar
Engine: 350 tpi
the kit has 2 fixtures. buy two kits
Old Dec 19, 2005 | 09:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Can you get those otto lights without the gay blue bulbs?
Old Dec 19, 2005 | 09:55 AM
jamon8's Avatar
Engine: 350 tpi
I am just not going to use the gay blue bulb and yes it is a bust out bulb
Old Dec 19, 2005 | 01:21 PM
Engine: 355
Too bad they dont make purple bulbs... It's going into a 92 RS hawaiin orchid or maui purple or whatever anyone wants to call it.
Old Dec 19, 2005 | 02:57 PM
Jim85IROC's Avatar
does anybody know of those H4 bulbs give a white white or is it that silly blue crap that I see on all the low-budget imports?
Old Dec 19, 2005 | 08:49 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
The site describes them as Hyper White bulbs, so I guess they give off white light.
I have a hard time seeing at night, so I'd really like to see how this works out. And how hard it is to install them (I know nothing about electrical work)
Old Dec 19, 2005 | 09:14 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
The H4 bulb is a low/high beam combination bulb. Why would you want that on a 4 lamp system like a 3rdgen Camaro?
In any event, if you decide to go this route (either the ebay parts or the Procarparts/Summit combination) and you don't like the blue bulbs, you can always pick and choose your headlight colors over at www.luminicsbulbs.com. They have the H4 bulbs in HyperWhite, UltraViolet, PureBlue or JDM Yellow. I can attest to the quality of these bulbs as I have them in both of my other two cars. One car uses H4 high/low beam bulbs, the other uses a combination of various 900x series bulbs for the high beams, another for the lows, and third for the fog lights. So I've got 4 pairs of Lumincs bulbs in total, and I've never had the slightest problem with them. I'm using the HyperWhites and they are just that - WHITE!
But here's another alternative completely. If you buy two sets of the above mentioned conversion kits, plus shipping, from the ebay seller you'll be spending $140. If you buy from Procarparts/Summit you'll drop around $100 for everything, shipping included (I just checked Procarparts on this, $25.67 shipping to California - ouch). Or you can just go to your local autoparts store and pick up Sylvania Silverstars for about $25 per lamp. You'll need the H4656ST for low beams and H4651ST for high beams, and all 4 lamps will set you back around $100. Or, you can get all 4 Silverstar lamps, shipped, for $87.30 at http://www.autobarn.net/silstarhalse.html
Yes, when/if a bulb burns out you'll have to spend the full $25 to replace it. But the initial installation is a piece of cake and you don't have to worry about burning up your wires.
It's nice having choices so I thought I'd share.
Old Dec 19, 2005 | 09:51 PM
black84z28-4spd's Avatar
i got my head lights from prostreet lighting...i got 4 bulbs and headlights for $80 shipped...here they are:
i am switching out the bulbs for silverstars down the road...but these with the fog lamps are bright as hell
Old Dec 20, 2005 | 07:58 AM
CrazyHawaiian's Avatar
Car: too many ...
I'm not really a fan of the H4 conversions (because of the heat) but when I used them in the past I always went with PIAA bulbs. Expensive but they are the best I've used.
Old Dec 20, 2005 | 11:14 AM
jamon8's Avatar
Engine: 350 tpi
this is the birds eye view that I was looking for. I did not buy the wiring harness I just got the 55/60 kit. My fog lights are super bright and should compensate
the lens is made of glass and there are tight fitting seals on the rear. cost of getting my headlights 38 dollars on VISA card.
Cost of getting the look I crave priceless
Old Dec 21, 2005 | 01:02 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Go to
James
Does the kit contain low and high beam fixtures? I was thinking about doing this also, but I was unsure about the set.
Old Dec 21, 2005 | 02:12 PM
jamon8's Avatar
Engine: 350 tpi
you have a camaro so if you bought these bulbs and fixtures that are capable of high and low in the same bulb so you would not utilize this and it would still work fine because you have high on the inside and low on the outside
Old Dec 23, 2005 | 11:40 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Out of all the above mentioned lights which are the brightest?
Old Dec 26, 2005 | 12:26 PM
jamon8's Avatar
Engine: 350 tpi
h4 100/90 bulb.
those are the ones that make me want to pull out a piece and make someone relace those bulbs
Old Dec 26, 2005 | 05:52 PM
Stevo's Avatar
Car: Pair of 92 Z28s
where do i get this kit...? maybe i missed where. Im only finding the 100/90?
Old Dec 26, 2005 | 05:58 PM
jamon8's Avatar
Engine: 350 tpi
the link above at procarparts.com has the kit with 100/90's or you can get the kit with the 50/65 and skip the wiring harness.
Old Jan 15, 2006 | 10:57 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
do i really need that harness because i bought the headlight conversion with the h4 bulbs and it plugged right in with the stock harness which is the 3 femal plug, my problem is that my highbeams are slightly on, so i disconnected them and the low beams conversion look normal any one have any close up pictures how u guy ran it or diagrams
Old Jan 16, 2006 | 09:55 PM
Vaneat-91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Go to
James
I'm considering this same option. I'd love to see pics and hear how they work.
Old Jan 22, 2006 | 12:33 AM
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Can you expand on the heat issue? Did they burn up the housings? Burn up connectors? Fry wiring? I'm concerned because I'm seriously considering this, and your the only one who has brought up any worries.
Old Jan 22, 2006 | 12:37 AM
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
What did you do for adapters? Or did you need them?
Old Jan 22, 2006 | 02:38 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Adapters are NOT needed (for a quad H4 setup)! However, you MUST rewire the plugs for the headlights (for a quad H4 setup). The wiring can handle the 'amps' no problem, it's just that the wiring between the H646 and H4 are different. Pull the spade connector out of the plug and relocate it according to the attached diagram.
After installing the H4 headlights I just plugged them in in, giving a VERY dim low beam, and a flickering high beam (not to mention the evil nasty glow of brown in the high beams when the low beams were on). It was only after setting another set of H4 headlights in my DeVille that I figured it out.
Old Jan 22, 2006 | 06:52 AM
Car: too many ...
I personally have had 2 problems with this in the past, one of them only melted the boots and connectors (this was on a 91 Camaro) the other one melted the boots and connectors and damaged other electical parts of the vehicle (this was in a 97 Chevy S10). But the thing is, this was all the result of running the high wattage bulbs and cheaper "unknown" brands. The wiring was correct, I just ran the wrong bulbs. If you run the lower wattage ones, what is it 55/60 or whatever you should have no problems. This is what I did to solve the two problems I had in the past. It was the 90/100 bulbs or other high wattages that gave me problems. The reason I always thought PIAA's were the best is because they work at the low wattages but produce the ammount of light the high wattage setups produce.
For best results I would recommend glass enclosures, not these cheap ones on ebay. Or at least ask the sellers on ebay if they are glass or not (who knows maybe it is). Don't let the gimmiks like angel eyes or otto whatever fool you. Glass is better because ot reflects the light better. If I was going to run H4's again I would run glass enclosures like Hella with PIAA bulbs and a voltage stabalizer which helps extend bulb life and controls heat. PIAA is also good because they have a range of outputs, I think from 2500K to 5000K, not exactly sure on that one. I used to run the 4000K ones at 55/60 wattage, nice white light.
Old Jan 22, 2006 | 08:08 AM
jamon8's Avatar
Engine: 350 tpi
ottos are glass
Old Jan 22, 2006 | 04:13 PM
Enyce31082's Avatar
Car: 1987 Pontiac Trans Am
i bought the conversion kit for my bird i ll have h4 and blazer fogs so i ll post pics of it on a bird unless someone already has it and wants to add any input before i do
Old Jan 22, 2006 | 05:24 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
looks good black84z28-4spd
Old Jan 23, 2006 | 10:00 PM
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Thanks, that clears up some issues for me.
Old Jan 23, 2006 | 10:02 PM
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
.....Don't let the gimmiks like angel eyes or otto whatever fool you. Glass is better because ot reflects the light better. If I was going to run H4's again I would run glass enclosures like Hella with PIAA bulbs and a voltage stabalizer which helps extend bulb life and controls heat. PIAA is also good because they have a range of outputs, I think from 2500K to 5000K, not exactly sure on that one. I used to run the 4000K ones at 55/60 wattage, nice white light.
thanks for the help. All good ideas.
Old Jan 23, 2006 | 10:11 PM
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Anybody know the difference between "euro clear" and "diamond cut"?
PCP has crappy descriptions of this stuff. The box they show has 55/60 on it, but the bulbs displayed are 100/90.
Maybe I'll fish around the net a bit more before I buy....
Old Jan 28, 2006 | 03:31 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
A: Anybody know the difference between "euro clear" and "diamond cut"?
B: PCP has crappy descriptions of this stuff. The box they show has 55/60 on it, but the bulbs displayed are 100/90.
A: That's just terminology for the style; there's no 'real' definition.
B: I bought the Otto units through PCP myself for my DeVille since they seem to have the best pricing (compared to eBay, where they hide the $30 shipping). The Otto units are really not that bad - I thought they'd be cheezy. They are nice glass, decent rubber boot, the 194 bulb seems 'pretty' water tight. They came with 55/60w bulbs, not the 100w.
My Camaro has "Eurolite" lamps, and they are better and worse - They LOOK better; the 'cut' pattern is nicer, and they have 3 fine horizontal lines across the front making it look like a lens is actually there. Since the Otto lamps are just clear glass, it almost looks like there's no lens!
Caddy (Otto lamps)
Camaro (Eurolite lamps)
The material is crappier though; plastic lenses, and one is cracked from heat. So I'd say the Otto ones aren't a bad buy.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
