New Parking Lights - SEAL or not to seal??
Old Feb 2, 2006 | 06:50 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Have you Replaced your FACTORY (old, dirty, water condensation ruined) ones for new OEM factory ones again?
The problem with 3rd gen's is that the plastic lens cover has a hole in it to let out condensation and water that builds inside however this always ALLOWS water inside. Has anyone here actually BLOCKED the hole? I am wondering if blocking the hole would allow consensation in, and not have a way to come out and would quite ruin my brand new parking lights (which I have yet to install).
Old Feb 2, 2006 | 07:06 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
why dont you drill the holes bigger so the water has a better chance to evaporate. there was a GM technical service bulletin about this. it can be found on TGO here https://www.thirdgen.org/newdesign/t...ensation.shtml
Old Feb 2, 2006 | 09:41 PM
Abubaca's Avatar
I drilled an extra couple holes.
It worked.
Old Feb 2, 2006 | 09:44 PM
Do any of you have PICS of this?
Old Feb 3, 2006 | 12:08 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Put two new ones on my car, taped up the drains, no problems. Got too close to a deer, shattered one and replaced it without taping it up, fogs up all the time.
Old Feb 3, 2006 | 12:43 AM
Ok, this is VERY Interesting! You mean it's better to PLUG the drain holes? How did you plug it?
Old Feb 3, 2006 | 07:18 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
It's sort of a slot type deal, I just put some duct tape over it.
Old Feb 3, 2006 | 09:12 AM
The slot is on the bottom of the light leading out the front right? You mean you can see a piece of black tape from the outside?? Do you have a pic of your car?
Old Feb 3, 2006 | 01:42 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
This area is behind the clear lens as I recall, anyway it's not visible from the front.
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
