For those who have detailed there brakes
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
What did you use to clean and prep the calipers for paint? I'm working with PBR calipers and I'm not sure what is safe to use on the aluminum.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I use "brake klean" but just becarful around paint... and skin, its nasty stuff.
Mine were dirty as heck, I used Engine Degreaser and a Metal Wire Brush to clean the caliper, but I applied the Degreaser with a rag so I could keep it from touching the rubber seals and stuff (dont want that stuff in there!) Then once the rear calipers (PBR) were looking like new, I did the same to the caliper carrier and center of the rear brake rotor/hub. Then I sent the rotors out to be turned, and when they came back I painted both the caliper carrier and the middle of the rotor/hub with black Engine Paint. Turned out looking awesome. I ended up doing this to the fronts too, though on the front I also painted the calipers and the spindles black. Looks 100x better. Here's a pic of the fronts after taking it out for a spin, should have let the paint dry longer LOL some of it came off when I put the wheels on. Sorry no pics of the rear online right now ..
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Car: 90 Formula
Not much Chris. Yea got a few "little" things to do with the bird to get it ready for AF. How's the IROC doing? No ignition problems I hope.
Car: 90 Formula
I'm pulling another "no one sees it until AF" deal with a few upgrades. Make sure you swing by and see it.
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
