10'' wide ROH RT's??
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I am getting some 18'' x 10'' wide ROH RT's, but I am really worried that they will stick out in the rear!! Does anyone have a 10'' wide ROH rim that can chime in here?? I know a few guys here have Drift R's, how is the fit? I really want to have the rear tires just inside the quarter lip(it is rolled though). I have a thirdgen rear end and the wheels will be ROH's thirdgen offset.
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Do you know what the offset or the backspacing is? If these are correct, you shouldn't have a problem.
Car: 91Z
I think the backspacing is 5.5?? I am awful with this whole backspacing thing, I don't really understand how it is measured. I know questions like this come up all the time, but searching did not really give me the answers I was looking for.
Car: '88 IROC
Axle/Gears: 9", Locker, 4.10's
depending on tires you can push the backspacing in a little to 5.5 in the rear but they will stick out a lot
i mounted 15x10 prostars on my car and they stuck out so i went with the 15x8's and im still gonna throw some fat rubber on there
17x11s on the rear. All he did was a little roll on the fender to get 11s to work, I bet you could get 10s in there with the right backspacing:https://www.thirdgen.org/techbb2/sho...hreadid=230160
10" width not sticking out: 'CrazyHawaiian', 'CarNDrvr', and a few others
This will help: http://www.4crawler.com/Diesel/Tires.shtml#WHEELS
I understood when I read this page. For a long time, I didn't know what I was looking for and I didn't know the difference between offset and backspacing.
Car: '88 IROC
i guess it depends what tires you are mounting also.... I was going to be working with 26inch tall and 11.5inch wide tires at the time so i couldn't realy push the backspacing that far in.
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
it can be done
10" wide with a 5.5" backspacing means the offset is right around 13mm with a frontspacing of 4.5"
basically
stock 16" gta wheel sits at 16mm offest with 4.63" backspc and 3.37" frontspc and fits in the well nicely
you have about 2-3" of extra backspacing available to further tuck the tires without rubbing depending on how low your cars sits and size of wheel its easy to measure
you should be just fine without any spacer if your information is accurate
basically
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
