Clear parking lights!
Old Feb 15, 2007 | 07:13 PM
  #151
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
nevermindd
Old Feb 15, 2007 | 07:24 PM
  #152
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
Originally Posted by camaroguy21
dubcity- My lights were not direct replacements. I had to cut out larger circles in the back of the metal bracket headlight brackets on my car in order to accomodate the larger connectors. You also have to remove the metal headlight rings and most likely the metal bracket headlight brackets themselves in order to then slide the new lights in. This part you would have to do anyway, even if you were just putting in new stock headlights. The problem here is that if you have nicely painted headlight pockets you could very easily scartch or even crack the paint.
ohh i not worried one bit about my paint
but so either or ill have to modify the brackets?
Old Mar 1, 2007 | 10:11 AM
  #153
the swede's Avatar
Car: Iroc-z
Originally Posted by thirdgenSS
anyone have pics of the clear park lights on a white car with silverstar bulbs?
Not with silverstar bulbs but on a white iroc .maybe it´s good enough .
Old Mar 1, 2007 | 11:29 AM
  #154
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i installed the lights but not the new harness yet and with the low beams on the bright lights are dim, do yalls do this also i dont like it i just want the low beams on and not both it looks kinda dorky, but hopefully the new harness will fix that. also how do you know which lights are the brights and which ones are the low beams, i installed them and the brights are no brighter than the low beams just bluer... maybe i put the high beams in the low beams and the low beams in for the high beams, ill play with the connectors and see if i can figure out which ones go where.
Old Mar 1, 2007 | 11:53 AM
  #155
Firebat's Avatar
Originally Posted by 89 brewcity
has any one ever tried to make clear parking lights on a firebird if so how was it done
I'm working on a tutorial right now on how to make the 82-90 firebird ones look really close to stock:
https://www.thirdgen.org/forums/auto...n-signals.html
Old Mar 24, 2007 | 11:39 PM
  #156
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: Clear parking lights!
just installed my clear lights thought id post sum pics of wut they look like on a white camaro
Old Mar 25, 2007 | 04:00 AM
  #157
Sinister Z's Avatar
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
That looks really good
Old Mar 25, 2007 | 10:39 AM
  #158
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Anyone know where to find them for a firebird?
Old Mar 25, 2007 | 06:23 PM
  #159
88305tbi's Avatar
Car: 88sc
Engine: 305 for now
Axle/Gears: peg
Attachment 135661
looks great!
what bulbs do you have in the signals? did you do the 4 light or only 2 light h4 upgrade?
Old Mar 25, 2007 | 10:47 PM
  #160
pearl_iroc's Avatar
Engine: LSX
Transmission: MN12
88305tbi i did do the full h4 conversion although it doesnt look that way, the outer housings are euro lights and the inner high beams are hella, but im gonna swap those out and get 2 more euro lights to match, as for the bulbs in the park lights i bought a set of led euro lite bulbs that are a direct replacement to the old yellow bulbs, thanks for the compliments guys
Old Mar 28, 2007 | 08:59 PM
  #161
UDAMON's Avatar
Car: Mazda Protege5
a great investment!
Old Mar 29, 2007 | 07:57 PM
  #162
Mic Stylezz's Avatar
From all these pics I do know one thing for sure I think the painted area around the heads lights that come on the fascia look alot better when there the same color as the car compared to when there black on a red car or black on a white car i think the black paint on a non black car looks too oldschool. I like those headlights and bumperlights the clear ones but is there anyone that doesnt put amber turnsignal lights in there? I think it would look cooler with some blue lights since its already clear and I know blue would be illegal but are blue lights/colored bulbs even available that actually shine blue?
Old Mar 29, 2007 | 09:55 PM
  #163
pearl_iroc's Avatar
Engine: LSX
Transmission: MN12
yea i agree, im not a big fan of painting the headlight buckets black
Old Apr 7, 2007 | 05:37 PM
  #164
hitmann91's Avatar
those look really nice. Probably a dumb question, but i cant get the stupid cover that goes over the lights off, can somebody tell me how to
Old Oct 16, 2011 | 12:07 AM
  #165
dwalt10's Avatar
I apologize for drudging up an old thread, but I wasn't sure of the best place to put this. I have an 86 SC without Ground FX. Earlier in the thread it says they have a smaller parking light, which it appears I'm running into because the DEPO clear parking light is about an inch too long to fit my car. None of the stores seem to recognize this problem, so what do I need to ask for to get the correct parking light? Even the OEM replacement type don't distinguish between two different parking light sizes. Any insight would be appreciated. Thanks!
Old Oct 16, 2011 | 06:21 PM
  #166
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
86sc i think still uses the earlier 82-84 standard or berlinetta (non z28 style).
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
Omega
LSX and LTX Parts
Aug 26, 2015 06:40 AM
tnrednneck
Aug 13, 2015 08:57 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
