HID (yes more questions)
Old Apr 6, 2006 | 03:14 PM
confucius101's Avatar
i just re-wrote this post b/c i'm tired and need a beer as well as 12hr's of sleep anyway
I need to upgred all of the lighting on my 91 firebird
i've search ebay and the boards but everything is mostly for camaro's
so can some of you please let me know what parts i need to ungrade all the lighting on this car (i'm a blind bat at night)
Mods i'm sorry if i posted this in the wrong place please move Thanks
Old Apr 6, 2006 | 03:31 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
6 lamps?
i suggest:
http://www.rallylights.com/hella/200mm.asp
Or you could just do what i did:
http://www.forshock.com/ta lights/overhead.jpg
Old Apr 6, 2006 | 03:34 PM
lol did i mention i was/am tired
2 head lights + driving / fog = 6
Old Apr 6, 2006 | 03:37 PM
Car: 85 Trans Am
Driving lights, jsut replace the bulbs, clean the housing. To replace:
http://www.rallylights.com/hella/ff075.asp
BTW, thats still only 4 Markers/signals replace bulbs
Edit: Summit carries both of those i believe
Old Apr 6, 2006 | 03:41 PM
lol i like you rmod butna thats not for me (not yet anyway
the 91 birds have 4 light fixtures (if that what you call them) in the nose/bumper and the 2 main headlights
ok back to your first link they have so many set's to chose from under the
h6054 ............. i'm just going to call them and order the brightest set they offer but what else will i need to run these????
Old Apr 6, 2006 | 03:44 PM
Car: 85 Trans Am
The vision plus is what you need for DOT standards, it uses an HB4 bulb. 60/55w bulb, just need the make the connections to the old connector (they will tell you, its also on the site)
http://www.rallylights.com/useful_in...amp_wiring.htm
Old Apr 6, 2006 | 03:46 PM
Thanks 4 the help
Old Apr 6, 2006 | 03:48 PM
Car: 85 Trans Am
no problem
Old Apr 6, 2006 | 03:53 PM
i think i'm gonna go with the
H6054N Kit with Hella Premium 100/80w Xenon +100% H4 Bulbs
or
H6054J Kit with Optilux 100/80w Xenon White XB +100% H4 Bulbs
and they want 70 for the wire upgrade
Old Apr 6, 2006 | 03:55 PM
Car: 85 Trans Am
Just like i said, those are not DOT legal. Ecode lights are great (thats what i have), but they might get you in trouble.
I had the silverstars from kragens in mine prior, they were pretty good.
Hella makes some bitchin lights though
Old Apr 7, 2006 | 02:15 AM
CrazyHawaiian's Avatar
Car: too many ...
Well are you gonna do HID's or H4's? There is a difference and I'm a little confused because the title of the post says HID but you guys are discussing H4 setups.
Old Apr 7, 2006 | 08:15 AM
hey at the time of post I really needed info on upgrading my lighting
and to be honest i'm not really sure on the difference
Old Apr 7, 2006 | 12:17 PM
Car: 85 Trans Am
HID lighting uses Gas-discharge arc lighting.
The H4s use a standard filament.
HID puts out more usable light (3600lumens vs 1600lumens)
H4 is cheaper ($100-200 vs $600+)
HID uses less OVERALL power, like 3 amps once warmed, but uses about 15 AMPS on startup.
H4 is usually constant at 7 or so amps (60 watts)
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
