91-92 firebird taillights to 85-90 trans am taillights
Old Apr 15, 2006 | 12:21 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
My friend got me a set of 85-90 trans am taillights for my 91 firebird what are the differences between 85-90 trans am taillights and 91-92 trans am taillights? also how do you make the 85-90 trans am taillights fit the 91 firebird the firebird has like 3 extra bulbs and theres a piece on the trans am tailights that keeps it from bolting to my 91 firebird. Can anybody help me out??
Old Apr 15, 2006 | 02:56 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
make your sig smaller and I'll tell you how to do the lights.
Old Apr 15, 2006 | 03:35 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
help
can i get any help now?
Old Apr 15, 2006 | 03:49 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
HAHA man that was messed up!
Hey buddy I wish I could help but i don't know much on head lights, try using the search button though
Old Apr 16, 2006 | 01:43 AM
Zepher's Avatar
First thing to do is get new bulb sockets for the turn signals as the ones on your car are too long. Get ones from any trans am with the all red tail lights like the 85-90 that you have.
Next, you have the option of lighting up the far right and left corners by using one of the small running lights that are on each side of your car, and then just remove the bulb from the other one on each side.
Drill a hole on the back of the far right pass side light and do the same on the far left drivers side light. you want the hole the same size as the small bulb socket that is on your harness, this will allow you to light up the entire tail light panel.
With the new sockets you aquired to replace the old turn signal sockets, cut the old socket off (you can see if there is space behind the tail light to leave it there so you can go back to stock easier) and put the new socket on. you may have to extend the wires a bit.
I'll see if I can take some pictures so that you can see what I am talking about, won't be till monday as I am going to be racing all day on Sunday.
Old Apr 16, 2006 | 07:34 AM
MNformula350's Avatar
I just used a 3 wire socket to light up the turn signals with the tail lights as well, I spliced in one of the white wires from the small sockets that aren't used with the T/A lights.
Old Apr 16, 2006 | 10:25 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
wiring harness
i found out that the easiest way without modifying stuff is to get the wiring harness of a trans am for the taillights. Everybody says it just unplugs it woudl be real helpful if somebody has a pic of were the taillight harness disconnects from.
Old May 9, 2006 | 09:12 AM
Dragonsys's Avatar
Car: 02 TransAm
I want to do this, only in reverse. I want to use the 91-92 tail lights on my 89 TA. I preferr the Amber blinker....
1992 Trans Am
May 10, 2023 07:19 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Thomas
Oct 3, 2015 05:34 PM
